will win ALDL work for '84 L69
Old Jan 7, 2002 | 12:21 AM
salty's Avatar
Will WINALDL work on the ecm for an '84 L69, does someone have one that does?
cheers
Old Jan 7, 2002 | 02:31 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Try the "CLCC 1984 Car, 1985, 1986" selection and let me know if it works.
Old Jan 10, 2002 | 05:42 PM
salty's Avatar
Thanks mate,
when i went to connect I found the serial data pin/wire on the aldl is missing, or was never there. I'll have a look at the wiring behind the connector to see if it has been removed intentionally.
Old Jan 10, 2002 | 09:47 PM
JPrevost's Avatar
Car: 91 Red Sled
They aren't always in the same place. The serial data wire from the ecm that is. You need to look at a simple Chiltons service manual for your specific vehicle. If it's got a different ecm or different style aldl then it'll be in a different position. The easiest way to go about looking for the serial data wire is to drop the ecm onto the floor and look up your ecm wiring diagram. Most good shops have this stuff on CD-rom etc. Then look at the color of the wire and it's location, find the same wire on the aldl and you're ready to tap in to the high life.
Old Jan 10, 2002 | 10:08 PM
salty's Avatar
I just got the chiltons manual and didn't think it had have that level of detail for the 84 ecm. I don't even know what model ecm it is yet, after swapping the speedo cable and heater core this weekend i'll pull the model number and do some research.
thanks
Old Jan 11, 2002 | 07:07 AM
deadtrend1's Avatar
my friend/neighbor has a LG4 Camaro, and im getting a laptop for 30 bucks maybe, so hopefully i can use that program. It wont work for the LG4 will it? And any where i can get a plug to go into the computer port so i dont have to always plug each individual wire in???
~Tim
Old Jan 11, 2002 | 08:33 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
What ECM does the LG4 have? Is it TBI or electronic carb?
/ Jonas
Old Jan 12, 2002 | 12:12 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
wow this is a very international thread.....
Old Jan 12, 2002 | 08:55 AM
deadtrend1's Avatar
the LG4 is a electronic carb.
Old Jan 12, 2002 | 10:47 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Then it will probably work. What year is it? 1984-1996 electronic carbs are supported, and it might work with newer too.
Louis Baiani is helping me to test the new version. He discovered that the ALDL timing is different compared to other 160 baud ECM's. We managed to make it work and he is testing it now before I release it.
/ Jonas
Old Jan 12, 2002 | 11:28 AM
deadtrend1's Avatar
its a 1987 camaro berlentta LG4 305 CID engine with a Rochester 4 Barrel aftermarkert bolt on carb.
Old Jan 15, 2002 | 05:14 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
The new release ( 1.05b ) is out now.
http://winaldl.webhop.net
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 17, 2015 02:52 PM
