TBI without electronic ignition?
Old Jan 7, 2002 | 01:34 AM
Tas's Avatar
Tas
can you run TBI without an HEI distributor, like if you're retrofiting it to an older vehicle? What would be messed up by not having the computer control the spark?
Old Jan 7, 2002 | 08:02 AM
fast_broker's Avatar
I asked this once before. I believe all you need to do is fake the ECU into thinkging it is controlling the spark by feeding the old-style HEI tach signal into one of the ECU wires, or something along those lines.
Old Jan 7, 2002 | 09:41 PM
steve8586iroc's Avatar
I think Holley calls it a 2D system. If you want to find out just put an old HEI distributor in your camaro and hook up the tach wire to the tach wire in the stock harness. With a wiring schematic it shouldn't be to hard to find the correct wire. If it runs and runs decently then it would seem to be a no brainer in a precomputor installation. Only thing I don't understand is if your going to use a GM tbi and ecm then why wouldn't you want a computer controlled distributor?
Steve
Old Jan 7, 2002 | 10:14 PM
Tas's Avatar
Tas
Because I just changed my cap and rotor on my Jeep. I don't wana pull it out and put in a 6cyl GM HEI if I don't have to. At least not yet.
92firebirdguy
Sep 1, 2016 07:53 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Jlanz55
Sep 6, 2015 02:35 PM
