Car doesn't fire
Old Aug 28, 2018 | 02:13 PM
DirtyDan's Avatar
Car: 1992 Camaro RS
Car doesn't fire
I have a 92 RS 305 tbi that will spin but won't fire in less a little starting fluid is used. Then it'll start run very rough then die immediately. Any idea to a cause? Also I should mention it ran the day before then I let the battery die overnight by mistake but I wouldn't think that would have done anything.
Old Aug 28, 2018 | 03:40 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Re: Car doesn't fire
Based on my recent experience w/ a random No-Start... start with the basics.
1. Do you have Fuel?
2. Do you have Spark? - Check between Cap & Coil, then between Coil and Plug
https://www.thirdgen.org/forums/tech...condition.html
Old Aug 28, 2018 | 04:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Aug 28, 2018 | 10:57 PM
Schurkey's Avatar
Yup, I'd want to know if the pump runs for 2 seconds when the key is turned "on", and whether there's fuel pressure during cranking.
Next would be to verify both power and ground for the injectors. A Noid light would be ideal.
If it runs on starting fluid, there must be spark to at least some cylinders.
The guy says it's TPI in the other thread.
I have no idea, but at least some of the diagnosis would be the same--TBI or TPI, it's going to need fuel pressure and power/ground to the injectors. Spark, compression, and exhaust seem to be likely since it runs on starting fluid--but he does say it runs rough, so having spark, compression and exhaust on all eight cylinders may be a question.
DirtyDan
Aug 28, 2018 12:55 PM
Mykogee
Jan 19, 2015 01:12 PM
cretecrawler
Jul 22, 2009 03:07 PM
AndrewSyndrm
Apr 27, 2009 05:21 AM
babybear82lilj
Feb 5, 2008 05:12 PM
