MSD Ignition Setup
Old Jan 7, 2002 | 12:08 PM
deadtrend1's Avatar
MSD Ignition Setup
I'm thinking about getting the 40 dollar coil from summit, but recently about 3 months ago i replaced my wires, plugs dist and rotor and all. Is it safe to just bolt ont he coil, (runnin AC delco Plugs, not rapidfire's) and leave the gap at .035. Or go with the new plugs wires, rotor and dist., and open the gap more to say .045?
Old Jan 7, 2002 | 07:45 PM
TBI305Camaro's Avatar
shouldnt need to change anything....unless you get a really powerful coil it should affect anything...if you talking about one of the MSD coils that fit your stock setup itll be fine..
Old Jan 8, 2002 | 02:49 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I did it, worked great. Quit being a pu$$y Tim and go for it already.
Old Jan 8, 2002 | 08:37 AM
deadtrend1's Avatar
LOL .. aight Eric .. ill do it and prove myself to you!!!!! yea!!!!
HAHA .... im not in the mood to change all my plugs again though, oh well
~Tim
Old Jan 8, 2002 | 12:50 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I accidently deleted my Ignition page dang it. So if u need any help u will have to e-mail me.
Old Jan 8, 2002 | 01:45 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The only annoying thing about the MSD coil I got was that the bracket (which was riveted on to the stock coil... grr) hit the glue that attacked the coil to its housing, so we had to grind down the bracket.
Its still only about a 30 min job, less if you know how to drill rivets out which my dad had to show me.
Old Jan 8, 2002 | 03:32 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
What I did was take a flat head screw driver and I took the whole coil and bracket out and I just banged on the flat peice of those rivets until I broke the flat part clean off and just wiggled the leftover rod. I didn't really care since MSD gives u screws and washers to replace the stock rivets that GM puts in there.
Old Jan 8, 2002 | 05:04 PM
JPrevost's Avatar
Car: 91 Red Sled
Install coil, really just a bolt in part. You don't need to gap the plugs but it wouldn't hurt to give it a little more gap. More gap the better the burn as long as the coil has a high enough voltage to jump gap.
Old Jan 9, 2002 | 02:18 PM
deadtrend1's Avatar
i'll probably take them out and re gap the. Chuck!, I've put a coil in before and its simple to get the bracket off. I used a chisel and hit the flanged edge off, then took a smalled one and drove it out.
~Tim
Old Jan 13, 2002 | 06:38 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Is replacing the coil with the one MSD sells really worth it for a car which is almost stock (just exhaust, pullies etc)? And the age old question did you feel any difference by just replacing the Coil or is the real gain really only going to be realized once an entire system such as a 6AL is installed?
Any ideas??
Old Jan 14, 2002 | 12:18 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
No, I mean the glue that attaches the plastic coil housing to the metal ... frame I guess. We had to grind the middle of the bracket so that the giant glob of glue wouldnt hit the bracket. We (pops and I) just drilled the rivets out, simple task.
The coil seemed to make the car run smoother. I wasnt lookin for a gain or anything, but it idled much nicer.
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
