quick open element question
Old Jan 8, 2002 | 09:09 PM
CamaroEFI's Avatar
i ready to put an open element air filter on my 91' TBI RS. 14"x 3" will fit under the hood right? whats all involved in doing this?
Old Jan 8, 2002 | 09:35 PM
JPrevost's Avatar
Car: 91 Red Sled
http://snflupigus.tripod.com/tech/op...tep1/step1.htm
Old Jan 8, 2002 | 09:38 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Here ya go.........
TBI Open Element Installation
AJ
Old Jan 8, 2002 | 09:39 PM
AJ_92RS's Avatar
Damn you Jon!!!!!
AJ
Old Jan 9, 2002 | 10:30 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the Moroso 14x3" flat bottom air cleaner. Fits perfect, no more spacer.
Part#65911, $47.99 at Summit.
-Rich-
Old Jan 9, 2002 | 01:29 PM
i roc k's Avatar
I own a 1988 305 tbi i put a 14x3 under the hood no problem but my brother owns a 91 305 tbi and the skrew that you will tighten it to didnt reach all the way up. Really easy to put on just take all the old stuff of cap the vacum line cover the senser that connects to the stock filter so you dont mess it up and just put on the new open element.
Old Jan 9, 2002 | 01:41 PM
TBI305Camaro's Avatar
i got a drop base 14'' k&n cleaner with a 3'' element and it fits fine but i took the drop base off and put a mr. gasket non drop base on it...with the non drop base you can remove the spacer ring and it will clear the throttle linkage fine and the hood clearnce is fine. definetly get a non drop base its much better
Old Jan 9, 2002 | 02:12 PM
i roc k's Avatar
I got a non drop base and i still got the spacer ring to and everything fits perfect
Old Jan 9, 2002 | 02:22 PM
deadtrend1's Avatar
What size is the element. That ring lifts it up pretty high.
Old Jan 9, 2002 | 02:25 PM
i roc k's Avatar
14x3 it supprised me to but it fits
Old Jan 9, 2002 | 05:37 PM
slider's Avatar
is an open air element much better than the stock one?
Old Jan 9, 2002 | 05:46 PM
JPrevost's Avatar
Car: 91 Red Sled
Yes. $15 from Summit racing. Non-drop base is better but it won't fit if you ever get a taller intake manifold. I got my drop base 14x3 to fit only after I used a ball hammer and pounded clearance for the TPS and IAC. I also had to cut the underbracing.
Remember that I have the RPM intake on vortec heads with a 1" adaptor plate and hte holley 2" TB so clearance is a big issue.
Old Jan 10, 2002 | 11:43 AM
HrdRockA4305's Avatar
If you get a drop base, even though non-drop is better, make sure that the base dosen't rub the coil wire! You can just move the coil back if it does. Trust me on this one.
Old Jan 10, 2002 | 08:21 PM
CamaroEFI's Avatar
what about the 14x3 Edlebrock from Advanced Auto Parts
Old Jan 10, 2002 | 09:23 PM
that should work fine...if you dont have the 40$ for a k&n filter go ahead and get a cheapo itll still flow much better than the stock air cleaner will...get a NON DROP base...much much better ive had noth and the drop hit my throttle linkage and you have to use the spacer ring...with a non drop you can remove the spacer and get much better flow and it clears everything
Old Jan 10, 2002 | 11:53 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Just some FYI, The drop base 14X3 Edelbrock did not clear the throttle linkage and some of the ignition components on my 91 Firebird. I tried a demo one in a Pepboys parking lot.
Old Jan 11, 2002 | 01:57 AM
JPrevost's Avatar
Car: 91 Red Sled
Like I said before, a ball hammer and an anvil work great to make the "cheap" open drop base fit anything. I'm running one on my holley TB and it doesn't hit the throttle linkage but that's probably because the holley version is slightly different than the rochester. Either way it isn't a hard work around if you have some leather gloves and about 15 minutes to burn.
Oh yeah, the K&N filter is good but it really REALLY isn't needed. A 14x3 filter is recommended for a 350hp 350 and that's a cheap paper element. Don't be fooled into thinking you need something when you don't. The K&N is great but believe me, $40 towards: a new high voltage coil, a wonderbar, or maybe a 180 thermo with low temp fan switch! If you've got the money go for it but last time I checked none of us want just looks, we want to go faster, yes/no?
Brinkkl2000
Aug 4, 2018 08:29 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
wruiz
Aug 13, 2015 09:07 PM
