Dual TBI problems
Car: 1982 TransAm
Engine: 8
Transmission: 200C Automatic
Axle/Gears: GU3 2.93
Dual TBI problems
start and run with winaldl hooked up
I have a 1982 TransAm 305 vin 7 car. It through a code 42 & 44 and I cant seem to find out why. Fuel pressure is good and when I hook up my winaldl and OBD Diagnostics inc serial cable the car runs ok and starts on first crank.when not hooked up it cranks for ever and runs like crap. I still have the codes. I have replaced the Ignition module cap rotor wires and EGR valve with no change. I have looked for vacume leaks and bad grounds. I have noticed when I first put the key to on, the fuel pump runs for about 5 secs and the #2 TB injector sprays fuel but the #2 injector does not , yet when the car does run booth injectors work normally. any thoughts would be appreciated.
Re: Dual TBI problems
Faulty (grounded) wire harness
Faulty ECM
The injectors must not spray fuel until the ECM gets an "engine turning" signal from the pickup coil via the ignition module.
Car: 1982 TransAm
Engine: 8
Turns out I had two bad ACEL ignition modules. Replaced with Delco and injector problem went away. Replaced O2 sensor and lean mixture went away. I now have no check engine light but still have a backfire problem when I advance throttle through about 1/4 but engine runs fine above and below that will check TPI next.
