Quick! I need Knock Sensor Help
Old Jan 10, 2002 | 04:41 PM
Nate Hanson's Avatar
Hey Guys-
I need to know if there is any other place i can screw my knock sensor in on my block because my conversion motor mounts cover my spot by the starter.
let me know asap
nate
Old Jan 11, 2002 | 04:00 PM
Damon's Avatar
How about the other side of the motor? Only a block mounting location will work and the coolant drain plugs are about the only place I can think to screw one in.
If you'd like to deactivate the knock sensor you can do so by simply running the wire through a 3900 Ohm resistor to ground until you figure out an alternate solution. Just to get you up and running.
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
masonta
Sep 1, 2015 06:40 PM
