dead engine
Old Sep 29, 2019 | 06:01 PM
crackmaster353's Avatar
dead engine
have had a 1983 Z-28 setting for a while but had it cranked and running about a month ago. Went to crank it and found battery dead, replaced battery and now I have no fuel coming through injectors. need ideas please!!
Old Sep 30, 2019 | 04:54 PM
Schurkey's Avatar
Re: dead engine
Gas tank empty?
Plugged fuel filter?
Fuel pump or pump wiring defective?
Failed distributor pickup coil or ignition module?
Failed ECM?
Stuck injectors?
Does it run if you drizzle some gasoline into the throttle body?
WHAT IS THE FUEL PRESSURE?
vyper883
Aug 28, 2010 03:08 AM
lukeylouk
Aug 20, 2008 10:46 AM
chicago22
Aug 13, 2007 11:56 PM
riprukahs
Jan 4, 2003 12:34 PM
RallySport92RS
Jul 7, 2002 01:42 PM
