iron eagles on 'vette 350 L83
Old Nov 10, 2019 | 02:15 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
got the 10024361(67cc chamber/165 runner)Dart iron eagles installed to replace tired old '624s: running good now after a little trouble on the first shakedown run-discovered stainless steel valves don't play well with iron guides-they will gauld and stick in iron guides-use bronze guides for SS valves...used chrome stem valves 2nd round MK2 Vortec stem seals fit iron eagle iron guide heads,and the rocker cover gasket surface is raised ~1/2" vs original heads,so plenty of clearance under the '84 magnesium covers for roller rockers.Machine work perfect on these heads including the valve jobs.Used #1094 shim gaskets for tight quench and no rattling when engine lugged-probably ~9.5 c/r with the stock TRW forged flattops.Does seem to be minor performance improvement idle-4000,but will see about higher RPM once weather clears again.
Old Nov 10, 2019 | 08:17 PM
Schurkey's Avatar
Re: iron eagles on 'vette 350 L83
What is a "MK2 Vortec"?
Old Nov 10, 2019 | 09:59 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
-2nd gen Vortec,96 up-1st gen would be '87-95 "swirl port "vortec" The Iron Eagle heads have similar"heart shaped" chamber design to 2nd gen Vortec
Old Nov 11, 2019 | 01:43 AM
Schurkey's Avatar
Did GM or the Chevrolet Division use the "Vortec" name for any V-8 prior to the 1996 5.0 and 5.7 versions?
So far as I know, prior to '96 model year, the only "Vortec" was a V-6. The swirl-port LO3 and LO5 that you describe were never called "Vortec", and Chevy never called the '96 L31 or the 5.0 stablemate a "MK2"..
Am I wrong?
Old Nov 11, 2019 | 12:23 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Am I wrong?
GM Marketing has called the swirl port heads "Vortec" since 1985.
Old Nov 11, 2019 | 01:39 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
here and there you will find discussion on pre-1996 "Vortec"SBC heads-my '06 Canyon has a "vortec 2900" The SS valves used in the ill-fated 1st shakedown were Ferrea-can say those can take a lot of heat-had to get a rosebud torch tip in the port and heat it bright orange hot to straighten it enough to get the keepers off-bought another exhaust valve to have complete set to use in a future bronze guide head someday.Used Melling valves 2nd time-those made in Brazil,about as good as you can get these days.
UNCLE TOM
Jan 26, 2015 04:24 PM
racerx520
Sep 15, 2013 09:08 AM
intex1982
Jul 6, 2008 03:22 PM
84H.O.Trans Am
Mar 6, 2004 11:38 PM
MrNova
Dec 27, 2002 04:30 PM
