Vortec Heads
Vortec Heads
I'm starting a build of a 355 TPI, this is a camaro 350 so it has cast iron heads....I keep seeing people talking about the Vortec Heads, can anyone give me any info? Like are these off a new Vortec motor or something? any info is much appreciated.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Vortec Heads
They are off vortec truck motors. They are cast iron and require centerbolt valve covers and a different intake manifold.
Have you tried google?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Vortec Heads
The "Vortec" heads being mentioned are off '96 - '00 V8 trucks ONLY
If they don't have 4 bolts on the intake side ( reg SBC heads have 6 bolts ) they are not Vortecs , no matter what the seller says
As already noted , plenty of info about then on the web if you take the time to
like
http://www.nastyz28.com/forum/showpo...35&postcount=2
Re: Vortec Heads
Vortec is GM's name for it's truck engines. First appeared in 1988 on a V6 and used many different engines since then
like
like
Thanks guys, i didnt know it required different intake manifolds....thanks for the info guys
Re: Vortec Heads
It would be worth your time to read this
http://www.compcams.com/information/...HP0201-002.asp
Car: 82 Z28
Transmission: T400
Re: Vortec Heads
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Vortec Heads
If you are looking for Vortec heads, stay away from the truck heads...also known as swirl port heads. You want the Vette/ camaro heads instead, they flow better. The only thing with the stock valve springs, they are limited on lift. So be careful if you're doing a cam swap too.
Car: 82 Z28
Transmission: T400
Re: Vortec Heads
The Vortec heads being talked about here only came on 96 - '00 TRUCK engines ; as previously stated.
More wrong info.
The swirl port heads you speak of were installed on the earlier (89 - 95 ? ) truck engines.
The '096 Vortec head being discussed is a cast iron version of the LT1 alum head used on the '92-'97 Corvettes and F-Bodies ( LT1 heads don't work on a reg SBC block anyway )
Got any documentation to back that claim up ?
The Vortecs will blow away any earlier stock factory head
Re: Vortec Heads
Not wrong info, a warning. Some people mistaken the swirl port heads as Vortec heads because they are center bolt design. It was just a "buyer beware" warning.
And I meant the Vortec heads are better than stock style heads.
Re: Vortec Heads
More wrong info.
96-2000 vortec heads flow better than ANY production cast iron chevy head EVER made for the SBC.
Re: Vortec Heads
Factory vortec heads can support near 400hp.
Re: Vortec Heads
O man, just realized what I wrote, that's what happens when you read things half asleep. Sorry guys!
Re: Vortec Heads
thanks guys for the info....since i wont be getting to the heads or cam for the engine till probably next year, im gonna look into possibly doing brand new heads from summit....gonna have to get more educated on all the info on the heads, cuz right now it list like 12 different kinds for a L98 lol
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Vortec Heads
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
