1990 Camaro 5.7 TBI starter issue
Old Apr 20, 2020 | 02:34 PM
will1990's Avatar
Car: 1990 Camaro Convertible
Engine: 350 5.7 L98
starter problem, the trigger wire (purple) is getting constant 12 volts and the cars starts cranking in accessory but will not fire up, also i do not hear any prime from the brand new ac delco fuel pump any suggestions ? another issue is the car is cranking both with or without the starter enable relay
recently installed, new ignition switch, new starter enable relay, new ac delco fuel pump with strainer, new fuel filter
Old Apr 21, 2020 | 01:03 AM
Schurkey's Avatar
Re: 1990 Camaro 5.7 TBI starter issue
First Guess: Welded copper disc in starter solenoid. Can happen any time, most common when battery gets weak and you try to start the engine. Voltage on the purple wire is back-feeding from the starter, not being supplied "upstream".
Remove starter, replace entire starter; replace only the solenoid; install solenoid repair kit, or just polish the bigass copper disc after breaking the weld.
Starter will crank until it melts the battery cables or you disconnect the cable from the battery. You cannot stop the starter from cranking as long as the battery is connected. If this isn't what's happening, then the disc in the solenoid isn't welded.
Fix the starter cranking problem before worrying about the fuel pump.
Rock90rs
Jan 6, 2020 07:56 AM
mcbitchman
Sep 29, 2015 12:32 AM
perZ
Sep 14, 2015 04:14 PM
linzbgoofy
Jan 15, 2003 08:52 PM
