new maro owner
Old Jan 14, 2002 | 12:39 AM
v8powr's Avatar
new maro owner
I am wanting to know what the best...... cheapest........easiest TBI mod is that I can do. I am not trying to have the fastest car.....just the best all around. Ive got a 90 maro w/ 305 and a 5 speed. I plan in the next year or year 1/2 to install 4th gen leather seats and t56 tranny 454 injectors and maybe lt1 cam. Im new so any advice will be well heeded. Ill keep yall posted. Its a slow process but im in no hurry!! see ya......[IMG]c:\camaro.gif[/IMG] [IMG]c:\camaro.gif[/IMG]
Old Jan 14, 2002 | 01:59 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Open element air cleaner (See Ultimate TBI in Technical Articles). Smog pump delete. Both mods are cheap, 1 is FREE!!!, and each can be accomplished in about 30 min. 'nuf said.
Old Jan 14, 2002 | 06:39 PM
nicksL98's Avatar
gut cat, good cat back system like dynomax, 3.42 gears.
oh yeah, its called a CAMARO, one more person writes "maro" and the lynching will commence!
Old Jan 16, 2002 | 06:56 PM
Tallboy's Avatar
thats the best mod for the least amount of cash(open element air cleaner)ull feel it in the upper rpm's
get the non frop base too or u might hit the throttle cable with aircleaner bottom
make sure 2 take off gold colored spacer ring too on the Throttle body... a 3" tall element should work(at least it does on mine)
they do make smalller....
u can remove the seal in the rear o f the hood to let the HOT air out and perhaps put a piece of hard rubber in the middle(maybe a 1/2")to open it up a lil more
a 180 theremo is good(and lower turn on fan switch)
or just wire up your own and manually turn on/off
do tune up
plugs,wires,cap,rotor
also keep reading and bookmarking info and sites
alotta people say a lotta diff things but there r sum constants
subs to chevy H P and car craft dont hurt either
i wish i could travel back in time and race my car when i first got it and see how much faster it is now LOL
Old Jan 17, 2002 | 07:20 PM
v8powr's Avatar
thank for the post.... right now my camaro runs beautifully... so to speak. I just moved to Louisiana from eastern Mississippi so I had to drive it like 8 hours(thats how I know it drives great!) Its got some pretty major stuff wrong w/ it right now though...like the T5 tranny is about to go...no reverse 3rd and 4th grind if ya dont shiftem just right, clutch is almost gone. I am just going to go w/ the T56 setup. got a radiator out of a cutlass so my heater core isnt hooked up.... i think my fan relays out so I just ran a hot wire. I gt a question too.... all my dash lights went out...any ideas of what it might be? and were is the smog pump located? Does it have a belt going to it? Ive got the one belt drives all system. Im gonna have bad a** car... but im just gonna take my time and doit right. See yall later and keep those camaros rollin....
Old Jan 17, 2002 | 09:16 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
why do you want to put 454 injectors? that would not make your car faster
slower yes, faster no
Old Jan 17, 2002 | 11:12 PM
v8powr's Avatar
in regards to the injectors....i heard that the 454 motor has a bigger injector...is bigger not better in this case? Are my stock injectors fine?
Old Jan 17, 2002 | 11:47 PM
HrdRockA4305's Avatar
Holley told me in an email that the factory injectors are good to around 250-260 HP, which is some pretty heavy mods on a TBI car. I'm keeping my TBI/Injectors unless I do a 350 swap and get a halltech ECM and 670 CFM TBI.
Old Jan 18, 2002 | 10:55 AM
v8powr's Avatar
thanks for the info....i guess thats just 1 less thing ill have to buy! in regards to my dash lights being totally out...any suggestions???
Old Jan 18, 2002 | 11:34 AM
JEFJM's Avatar
Does you radio display work when the headlights are off, and disappear when you turn them on. If so it's probably a transistor on the left wall under your driverside dash panel. I'll try and get the info on the part, but I bought mine from radio shack.
Old Jan 18, 2002 | 06:15 PM
v8powr's Avatar
well....to make diaganosis a little bit more difficult, i dont have a radio in my car!! What happened was the light switch rotates to make the panel dimmer and brighter right?.... well i turned it one day and the dash lights flickered and then went out. I thought it might be the switch but Im not sure. headlights and tails still come on so idunno.......
Old Jan 19, 2002 | 01:44 PM
JEFJM's Avatar
It sounds to me like it's most likely the transistor. The transistor will cost you $2.95 and the switch that I replaced was about $25. When the transistor went out on my car it fried the switch also as well as the fuse. It's possible the same thing happened on your car, but I'd try fuse and transistor first. BTW, the transistor is NPN silicone, whatever that means, but you're radio shack guy should be able to look it up. Just tell him you need an NPN silicone transistor that lists for 2.95. Let me know if there's anything else I can help with. I was without dash lights for three months, so I know what it's like .
Old Jan 19, 2002 | 02:53 PM
v8powr's Avatar
thanks alot for the info. Ill check it out and let ya know what I come up with.
Old Jan 20, 2002 | 05:38 PM
1MEAN92RS's Avatar
Engine: LO3
1st, don't do this mod if you have to pass emmissions (visual or sniffer) or if you don't want to spent 20-30 minutes putting this assembly back on every inspection time. This mod only gives you 1-3hp but it drops about 12 pounds and most importantly, removes engine clutter!!!! The smog pump is located directly below your AC compressor. Remove all the hoses going from the CAT and manifolds to it first and plug them. Then remove the pulley from the pump (best to loosen these bolts initially with the belt still on), remove the 2 bolts that attach it to the mounting bracket and drop it out the bottom. You usually can't get it out the top without cutting a notch in the fan housing. You will need a longer belt for the smog pump delete. 96.8in. 6 rib I believe. Check out the technical article if you have any questions.
Old Jan 20, 2002 | 09:10 PM
v8powr's Avatar
awesome!! that sounds like the cheapest thing i can do right now..being that i have to save for a t56 and the install. A few months ago i bottomed out the car on accident and it ripped a huge hole in the exhaust right behind the cat converter...since i dont have aftermarket exhaust is the ok, or will it hurt my engine by not giving it enough backpressure? My cats not gutted and it isnt loud or anything just got sort of a rumble to it. Maybe itll give me a little lo end boost untill i can afford the real thing. Well im fixin to watch fast and furious again.... maybe i will see bad a** camaro i missed before messing up those foreign cars!!! See ya....
Old Jan 21, 2002 | 02:57 PM
v8powr's Avatar
aww forget it!!! I just found a guy down here in Leesvile, La that showed me some pictures of some work hes done at his shop. Im just gonna go with a TPI 350 and a T56 tranny! The 305 is a real motor but there are too many millitary people around here with fast stuff and I just have to be able to compete!! Im sure all the 305ers understand! Jerry is his name and I seen some pictures of some stuff that was awesome...like in a hp chevy mag awesome! Hes gonnabe my main man so I hope by the end of summer I will have the motor and tranny in place. if yall run across any deals on the motor or transmission hit me up bwy18@hotmail.com
Lbibb
May 5, 2016 12:00 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
