George Klass
close
- Join DateMar 2017
- LocationMontreal
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1989 Trans Am
- EngineL03
- Transmission700R4
- Axle/Gears3.42
- Liked:49 Times in 37 Posts
Unfortunately I don't have the time or knowledge to tune my car. Do you guys recommend anyone reputable who can burn me chip?
Just something to improve the stock tune. Pull some fuel at wot, better timing tables, etc etc. Of course not looking for max power, just something more aggressive than the factory.
I am planning on at least buying an ADLD cable to datolog. I have some limited TunerPro experience when I was making some minor adjustments to a tune I had gotten on my Mustang (95 GT -- OBD1 EEC-IV) and burning the chip with Moates products.
I've done some research for a while. some say stock tune is fine, some say leaves a bit on the table. Confused at this point.
Within the next few months I plan on installing some older Hedman shorties and y pipe a friend IROC outgrew. Will be matched to a 46669 exhaust pipe and an SLP dual/dual muffler. Only other mod is an Edelbrock air cleaner. Car is also getting a new Yukon posi and clean used stock 3.42 donation gears next month. Excited to throw the 2.73s in the garbage.
Car will stay like this for a while. I did have some older World heads donated to the cause lol. My plan is to eventually run them with an LT1 cam, stock intake and TBI with bigger injectors. I know will definitely need more serious tuning by then.
Not looking to set the streets on fire with my 305 but I'm scared of almost anything that tries to race me sighh.
Thanks everyone
Thanks everyone
dmccain
close
- Join DateMar 2014
- LocationSouth Ms
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car89 Firebird
- Engine355 TBI
- Transmission700R4
- Axle/Gears10 Bolt.Posi-3.73s
- Liked:811 Times in 550 Posts
Check with "Tuned Performance" here on the board. I got a chip burned with a bit more timing curve, changed my TC lockup to 60mph, tuned out the speed limiter, and deleted vats. Car definitely runs better too it was worth it.
George Klass
close
- Join DateMar 2017
- LocationMontreal
- Car1989 Trans Am
- EngineL03
- Transmission700R4
- Axle/Gears3.42
Quote:
Will definitely get in touch with him. Thanks sirOriginally Posted by dmccain
Check with "Tuned Performance" here on the board. I got a chip burned with a bit more timing curve, changed my TC lockup to 60mph, tuned out the speed limiter, and deleted vats. Car definitely runs better too it was worth it. dmccain
close
- Join DateMar 2014
- LocationSouth Ms
- Car89 Firebird
- Engine355 TBI
- Transmission700R4
I can tell you a new posi and some gear will wake it up.Im running 373s but your choice of 342s is even better. A good shift kit and mild T/C helps also that's about all the mods I have. Im also running a bit more fuel pressure @14lbs. Car is a lot more fun to drive than the way it came and I think with your mods you will really see a difference. BTW what an awesome car you got there ive been following since you first posted on here.
George Klass
close
- Join DateMar 2017
- LocationMontreal
- Car1989 Trans Am
- EngineL03
- Transmission700R4
- Axle/Gears3.42
I'm so excited for the gears and posi. She needs all the help she can get haha!
I'll put an update on the thread one of these days! Glad you like her
dmccain
close
- Join DateMar 2014
- LocationSouth Ms
- Car89 Firebird
- Engine355 TBI
- Transmission700R4
I've almost got my 350 together and should be swapping in the next month or 2 hopefully. If you don't have a chip by then I would let you get mine I don't think I had but maybe $60 in it.
George Klass
close
- Join DateMar 2017
- LocationMontreal
- Car1989 Trans Am
- EngineL03
- Transmission700R4
- Axle/Gears3.42
Thanks for the offer but already made the move with Tuned Performance haha!
dmccain
close
- Join DateMar 2014
- LocationSouth Ms
- Car89 Firebird
- Engine355 TBI
- Transmission700R4
Good deal. He is the man.
