Yes I got a question I got a 86 or an 88 350 4 bolt main TBI I'm trying to figure out
Old Jul 22, 2020 | 01:04 PM
Mikejackson 75's Avatar
Car: 2011 MALIBU , 95 SILVERADO
Engine: 1986 TO 88 350 5.7 L SGI 4 BOLT MAI
I got a 350 4 bolt main come out of a 86 or an 88 is it the l05 or is it the l98 I'm trying to figure out I can't read all the VIN numbers the numbers on the back of the block bellhousing 14088548
Old Jul 22, 2020 | 04:13 PM
GeneralDisorder's Avatar
Re: Yes I got a question I got a 86 or an 88 350 4 bolt main TBI I'm trying to figure
L98 was TPI, not TBI. So it would be an L05. Being a 4 bolt it was most probably originally from a 3/4 ton or larger truck or chassis. Most L98's were 2 bolt with the possible exception of the Vette L98 which had TPI and aluminium heads so it's not one of those.
GD
Old Jul 22, 2020 | 04:33 PM
I'm getting ready to buy a cam and I need to know exactly what it is i can I get numbers off the crank or the cam or is there any numbers underneath a timing chain cover it says CFM 548 on the side of the block. 207, 201 and a. G35 UNDER TIMING CHAIN COVER
Old Jul 22, 2020 | 04:40 PM
BIRD91ZRAG's Avatar
You're going to have to look in the lifter valley and see if it has provisions for the roller cam spider. 86-88 can go either way.
Old Jul 23, 2020 | 08:28 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
This is what an L98 will look like in the lifter valley.
TexasRebel
Apr 10, 2008 10:30 PM
MillerTime21
Aug 5, 2007 01:24 PM
Ian Factor
Nov 24, 2002 10:40 PM
theGAME
Mar 6, 2002 01:43 PM
TheWraith
Jan 14, 2002 12:17 PM
