Quick question about plugs/wires, did I screw up?
Old Jul 24, 2020 | 12:35 PM
magicdave2's Avatar
Car: 1983 Pontiac Trans Am Recaro
Engine: CFI 305
I'll blame it on the insane heat/humidity on the day I did the job. I replaced the plugs/wires and for some reason I put a small bit of anti-seize on the plug contacts and the contacts at the distributor. I fired it up for a test and it seemed to run fine. My question is, does it matter?
Or, should I go through and pull the boots and wipe off the plugs and spray the boots with contact cleaner and wipe off the contacts at the distributor?
305 TBI V8
Thanks!
David
Old Jul 24, 2020 | 04:50 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Re: Quick question about plugs/wires, did I screw up?
You'll be fine
Old Jul 24, 2020 | 05:26 PM
NoEmissions84TA's Avatar
The anti-seize might end up working better than the di-electric grease that should have been used. I say leave it also.
Old Jul 24, 2020 | 09:42 PM
magicdave2's Avatar
Engine: CFI 305
Thanks for the replies! I appreciate it!
Old Jul 25, 2020 | 07:14 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
The anti-seize I am familiar with has powdered aluminium or copper, as an ingredient. I can see , in time, it transferring down the onto the ceramic and causing a short. If it were my work, I'd replace it with Dielectric grease. The smaller the quantity, the less likely.
NCcowboy
Mar 29, 2012 06:04 PM
spiderhole
Mar 2, 2008 11:57 AM
spiderhole
Feb 23, 2008 01:03 AM
White_russian5
Jun 14, 2006 08:50 PM
TransAm87
Apr 26, 2002 11:26 PM
