Intro and 1983 Crossfire resurrection.
Car: 1983 Z28 Crossfire
Transmission: 4 SP Auto
I had the whole story typed out and submitted and it didn't show up. So this is just a test.
Re: Intro and 1983 Crossfire resurrection.
Well I will type it again I guess.
I purchased this 1983 Z28 Crossfire in 1992. It had some damage on the right front. I put a new nose, right fender and a metal hood on it and drove it for a few summers that way. Then around 98 (that is the inspection sticker on it now) I parked it and decided I would not drive it again till I could restore it correctly. Well life happens and it has been (improperly) stored in a shed with a concrete floor for the last 16 years.
Which brings me to the TBI part of the post. The fuel pump does not run. I have power to the connector. So I pulled the tank. Of course old fuel and lots of rust. So I am getting a new tank. Probably this one.
https://www.ebay.com/itm/Fuel-Gas-Ta...918301030#rwid
I could not find a listing for the sending unit/ hanger for an 83 so I think I will get this one. 85 to 92 TPI. It will need some mods but it has the 4 lines and three wires. I may have to swap my old connector on it and just not use the threaded connection for the fuel feed. I will need some guidance on reducing the pressure to the 14psi. Also need to know if the fuel level sender is the same so the guage will work.
I have most of the rear suspenion out to remove the tank. After I get it running I will detail everything starting a the back and get all new rubber bushings and brakes and lines etc and work my way forward. The original exhaust still looks pretty good. I may want to go with a larger exhaust later but for now just want to get it running and make a nice driver out of it. It will need a lot of stuff when I get to the top side. Seats and carpet, rubber seals and window felts. And paint, but those are all threads for the future.
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
https://www.amazon.com/dp/B08DFLWGKX...ickstream_3_dp
If I use the higher pressure pump that comes with the sending unit I plan on buying will the factory regulator be able to handle it or willI have to get some aftermarket regulator to drop it first?
Will the sending unit on this 85 to 92 hanger work correctly with my 83 gauge? Same resistance? I am leaning toward going with this one and addding the correct year pump to it. I can still adjust the pressure up a bit and not worry about running too high.
https://www.ebay.com/itm/Fuel-Gas-Ta....c100752.m1982
Also are there any pictures around of opening the rear TB to adjust the regulator. I have looked but don't see any. A few old posts about it but no pics.
Axle/Gears: 3.31
Yes that helps for sure. Thanks.
I have been digging around some more and found a youtube video about it too. Also determined the resistance for both the 83 and 85 sending units are 0 for empty and 90 for full so should be able to adapt the later hanger into my new tank.
