Code 24 Vehicle Speed Sensor
Old Jan 16, 2002 | 05:10 PM
Turbo Bob's Avatar
Got a service engine soon light on my 91 Camaro RS 305 TBI, code 24. Speedo, odometer, and cruise control do not work. No loss of any kind of performance or driveability. Replaced VSS on driver's side tail shaft of trans with new unit. Same condition. No change. Please send help.
Old Jan 19, 2002 | 02:53 AM
Jza's Avatar
Jza
Check and/or replace the VSS buffer. It's either by the ECM, or behind the gauge cluster depending on your car.
You won't have any performance loss, but you'll suffer some definite mileage loss (about 3mpg), and may notice a fuel smell when you shut off the car.
Old Jan 20, 2002 | 10:40 PM
CamaroEFI's Avatar
im having the exact same problems with my 91 305 RS. i also replaced the speed sensor but that didn't help. please let me know if you find or fix anything.
thanks
Old Jan 21, 2002 | 09:48 AM
Turbo Bob's Avatar
VSS Code 24
As soon as I check the VSS buffer, I will let you know if that's the problem and where it's located in the car.
Old Jan 22, 2002 | 03:52 AM
Jza's Avatar
Jza
It's by the ECM for 91s. 'lil yellow box.
Old Jan 22, 2002 | 09:55 AM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
vss
my 92 rs has the same problem. theres a little black box next to the ecm. whats that?
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
