which LT1 cam
Old Jan 16, 2002 | 07:28 PM
jagone's Avatar
which LT1 cam
If I could pick, which LT1 cam is the best. I think I remember reading on here that there were 2 or 3 different grinds but I couldn't find them when I tried searching. This would be going in my 90 305tbi. thanks guys.
Old Jan 16, 2002 | 08:31 PM
JPrevost's Avatar
Car: 91 Red Sled
They're all very similar. I couldn't tell you for sure if there is a different grind or not but I do know that some early years the Lt1 was rated at 275hp and later it was bumped to 285. Again, I don't know since this isn't a forthgen.org! Ask on the camaroz28.net board.
Old Jan 16, 2002 | 08:47 PM
jagone's Avatar
I know it isn't a fourthgen.org, this question applies to my 3rd gen. I also know the horsepower bump you are referring to was in 96. I have read on this sight that there was a difference I just can't find it in the searches. Anyone else know? I will give it a try on the other board also.
Old Jan 16, 2002 | 09:25 PM
Tas's Avatar
Tas
All 7 cams have been listed in the past. Try to search for the post.
Old Jan 16, 2002 | 09:58 PM
BahamutRS's Avatar
I know which LT1 cam you should get...mine! :P
Old Jan 17, 2002 | 12:09 AM
vjo90RS8's Avatar
Car: 2002 Z28
i think the 93-95 LT1 cams had .450/.450 lift ( intake/exhaust), and the 96-97 cams were .450/.460, alittle more lift on the exhaust side. If you can, get one that was from a 96 or 97 camaro.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
masonta
Sep 1, 2015 06:40 PM
