Temporary fuel delivery for 91 305 TBI
Old Feb 11, 2023 | 11:00 AM
tlman12's Avatar
Hello everyone,
I have a 91 Camaro RS 305 TBI, it's sat for close to 4 years while I saved up to start building it out (project car). I put in a fresh battery, Distributer and CAP are new (less than 2 years because I had to move it once). It starts prefect (surprisingly) and almost tries to idle when spraying some engine start in so I'm thinking there's about a 99% chance that the fuel pump is bad, especially since it doesn't do the tell tale buzz when I turn the key on.
My question is, is there any way that I can throw together some type of temporary fuel delivery/pump setup so that I can move it? It has to be put on to a trailer and taken to another location and where it's currently parked it's going to be a PITA if I have to get something to it to pull it or if I have to try to pull the fuel tank.
would it be as easy as using a transfer pump somewhere in the 10-15 psi range connected directly to the fuel input pulling out of a gas can? or is there going to be something a little more complicated than that? does the temporary fuel container itself need to hold pressure?
Thank you
Old Feb 11, 2023 | 07:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Temporary fuel delivery for 91 305 TBI
You can fab up a "boat tank" with some hose and a 10psi pump. Some power them off a drill battery. I wouldn't drive this way, but see no harm to use it to get it on a trailer. Make sure it still goes through the regulator and put an inline filter as well.
willdog666
Jul 28, 2012 08:42 PM
chevycamaro91rs
Jun 25, 2011 06:24 PM
Kevman
Sep 6, 2010 05:47 PM
cjpro
Feb 11, 2009 09:51 PM
LuvRagtops
Nov 15, 2008 07:53 AM
