Planned Build 305 TBI // Thoughts?
Old May 22, 2023 | 09:39 AM
Caboose's Avatar
Hi All,
I got a 1990 Camaro RS Convertible with the famous 305TBI.
Love the car and want to keep the engine but just want a little bit extra.
My thoughts are:
- Headers, Y-Pipe, 3" Exhaust (Summit Headers, Flowtech Y-Pipe, Flomaster Exhaust incl. High Flow Cat)
- TBI-Mods (Maybe also a Spacer)
- Camshaft (something like 215/215)
- 3.73 Gears
What does you guys think? Anything I missed? Anything I definitely should not go for?
Hoped to gain maybe 30hp
Chris
Old May 22, 2023 | 11:18 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Planned Build 305 TBI // Thoughts?
Gears, exhaust, bump up the FP, TC.. All that is good for a lil bump in the SOP but I wouldnt go through the trouble of a cam change, id save that effort and time for a 350 swap.
Old May 22, 2023 | 12:54 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree with this, but either one will require DIY chip tuning. Start learning that now or skip the cam swap. The car will be fine with exhaust and intake mods, but you'll lose all the benefits of a different cam without the EPROM tuning.
Old May 22, 2023 | 03:51 PM
Caboose's Avatar
Question to the Chip: What's better: Doing my own Chip (currently I don't have any Equipment for this) or just order one?
Old May 23, 2023 | 08:12 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You'll have to do it yourself unless you constantly data log and send it to someone to review and burn a new chip. That will be slow and repetitive. Luckily, there is tons of info on DIY EPROM tuning on this site. That is unless you know someone locally that knows how to tune EPROMS.
Old May 23, 2023 | 06:16 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
If you are planning on tuning a single GM vehicle I would get an EBL Flash and save yourself the trouble of finding a bunch of discontinued and hard to find tuning stuff.
Old May 24, 2023 | 12:04 AM
Schurkey's Avatar
Why handicap yourself by keeping the 305? You're instantly giving up 50-ish ft/lbs of torque you'd have with a 350.
Old May 24, 2023 | 04:58 AM
Caboose's Avatar
Thanks for all that good feedback.
Another stupid idea (found on ebay):
I just found LT1 Heads (Casting: 10125320 )
- Would these fit?
- Should bump up some horses?
- I'm guessing it also need some PROM tuning, right?
Old May 24, 2023 | 06:44 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
- Would these fit?
gen 2 heads won't work without extensive modification that is beyond the scope of the project. Also not worth the effort. They'll bolt up but thats about the only easy part
Old May 26, 2023 | 09:38 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
The LT1 heads will need a new coolant cross over and a couple holes welded up. Also will need new holes drilled for the intake to bolt on. If you can weld aluminum then its not a big deal, if not its going to be a chore.
Old May 26, 2023 | 08:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Because it is a convertible and a 7.5" rear along with an equally weak 700r4 or T5.
Old May 27, 2023 | 12:26 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
If I was doing a mild upgrade on a '90 rs L03,i would: 3.42 rear,exhaust upgrade from manifolds back(no need for headers on a very mild hop up),swap out the grocery-getter cam with a mild ECM friendly one,possible small fuel pressure increase and see how it goes Ithink 3" exhaust is a little big for the situation-2.5" about right.
Old May 27, 2023 | 05:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Manifolds is one place you are wrong. The LG4/L03 manifolds are the absolute worst flowing trash you could ever put on an engine. Swapping manifolds for headers even shorties will give bigger gains than a cam. The 90-92 LB9s lost 25 hp and 15 ft/lbs using the LG4/L03 exhaust rather than the L98 dual cat. Most of that loss is the manifolds themselves.
Dual 2.5" to single 3" is what you want for exhaust for a mild SBC, it just plain works.
Eustace16
Jun 10, 2009 02:49 PM
I H8 WWD
Nov 17, 2007 01:30 PM
winsor33
Jun 9, 2005 11:24 AM
no1kicker
Mar 25, 2004 09:32 AM
Soule88SC
Aug 19, 2003 10:51 PM
