Very low idle at cold start
Old Jun 16, 2023 | 01:32 AM
PolishRS's Avatar
Car: 1991 Camaro
Engine: 305 TBI
Hey guys! I can't find a solution to my problem here on the forum, so Ive decided to create a new thread. My 305 tbi with a new IAC and new TPS(all set up correctly) idles very low at startup. When it warms up a little it's okay, it holds rpm at about 700 but at startup where it should jump to let's say a 1000 it doesn't do that, starts at 500 and if I don't pedal it a bit it'll stall. No error codes. I know the best way to diagnose it would be to plug it into a PC, but unfortunately here in Poland it's pretty difficult to get a working aldl cable for the Camaro as they're pretty rare. Thanks in advance.
Old Jun 17, 2023 | 01:06 PM
Schurkey's Avatar
Re: Very low idle at cold start
I'd want to know if the IAC was working properly, and if the computer was getting a proper signal from the coolant temp sensor.
It'd be enormously easier to discover both of those things with a scan tool; but y' gotta do what y' can with what y' have.
Old Jun 17, 2023 | 01:49 PM
PolishRS's Avatar
Car: 1991 Camaro
Engine: 305 TBI
Thanks for the reply.
Exactly...
I tested the CTS with an ohmmeter and it seems to be okay. I tested the IAC in a stupid way of taking it out and turning the key with aldl pins shorted, of course it shot out and I've spent an hour finding the inside of it when I put it back together I cranked the motor and it went back inside the casing, so I guess it's working (if properly, I don't know). I'm a bit scared it might be the ECM as the car was standing in tall grass with busted windows for a few years before I bought it.
senior bear
May 2, 2016 02:13 AM
torqer
Mar 10, 2010 08:39 AM
zrated57
Mar 11, 2006 03:39 AM
REALPOWER
Dec 5, 2004 01:16 AM
25THRSS
Oct 15, 2003 06:46 AM
