Fuel lines
Re: Fuel lines
Would this work?
https://www.racetronix.biz/p/adapter...adf-6jm1615sgf
what sizes do i need for feed and return?
Car: check
Engine: check
Transmission: check
Re: Fuel lines
Be sure to use a modern line for these. No common CPE lined SS braided. They will weep fuel fumes like no tomorrow. There is either PTFE lined hose or Viton lined hose that works with fuel.
RBob.
RBob.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Fuel lines
I did this. I used these fittings / lines: for a TPI motor as I could not get the OE rubber lines:
I only have3 one part number for one fitting atm but you need 2 sizes... I beleive it is 16 and 14mm
EAR-AT9894DBHERL
Fragola Performance Systems 6000 Series PTFE-Lined Braided Stainless Pre-Made Hoses 6026-1-2-12BL
EAR-AT9894DBHERL
