Vacuum Leak or Normal?
Old Oct 21, 2025 | 12:53 PM
Jardin M. Bell's Avatar
Car: 92’ Camaro RS Convertible
Engine: 305 TBI
92 Camaro RS 305 TBI
Im having a high idle issue.
I used smoked machine through brake booster hose & im getting smoke through the throttle body, right by IAC valve..
It’s the only place I’m seeing smoke.
Is this normal? — throttle body has new gasket.
Old Oct 21, 2025 | 01:45 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Vacuum Leak or Normal?
Yes, b/c the IAC valve is partially open, smoke can/will pass right through it.
Old Oct 21, 2025 | 08:35 PM
Engine: 305 TBI
Thanks for the response.
I guess Vacuum leak isn’t the issue.
I’ll look into replacing the IAC valve & see if that changes anything.
Old Oct 21, 2025 | 11:09 PM
Schurkey's Avatar
How about TESTING the IAC?
Connect a scan tool, find out what the computer wants you to know.
Old Oct 22, 2025 | 06:48 PM
Engine: LT1, L400
Agreed.
88formula305tpi
Jan 13, 2021 08:43 AM
79Daytona
Oct 29, 2020 04:26 PM
insomniac
Apr 21, 2012 12:15 PM
2011calvillo
Dec 9, 2011 12:12 PM
