89 camaro throttle body idled up high.
Old Dec 8, 2011 | 10:34 PM
2011calvillo's Avatar
Car: 1989 camaro rs
Engine: 5.0 (305)
Transmission: 700R
What can i do to get it at a low idle rpm, what could be the prob??
Old Dec 9, 2011 | 06:43 AM
ex-x-fire's Avatar
Re: 89 camaro throttle body idled up high.
Check the recent post "really stumped needed help".
Sounds like a vacuum leak.
Old Dec 9, 2011 | 08:23 AM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
prob either a vacuum leak or a bad idle. usually is a base gasket.
spray wd40 around the base of the throttle body while the engine is running. if there is a leak, the wd40 will teporarily seal the leak and lower the idle.
Old Dec 9, 2011 | 12:12 PM
Ronny's Avatar
Make sure you have correct gasket if you replaced.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
