LT-4 hot cam????
Old Jan 25, 2002 | 06:47 PM
Dans91's Avatar
Car: 91 RS
LT-4 hot cam????
I have a question on the LT-4 hot cam, would it work well with a 91 TBI 305. Is the LT-4 hot cam compatible with emissions for california.
Also I have a 69 350 block, can i switch it to be a hydraulic roller cam with the LT-4 hot cam kit. Well any help would be great and deeply appreciated. Thank you much
Thanx
Dan
Old Jan 25, 2002 | 06:59 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I asked this same question a while back and the general concensus was that .525" lift is a bit much for a 305. Once you get up around .500 lift valve shrouding starts to become a problem due to the small bore. It would probably do well on that 350 you've got in the works though...
Old Jan 25, 2002 | 07:53 PM
steve8586iroc's Avatar
The LT4 hot cam kit will not work on a 69 block without a lot of extra work if it will work at all. Maybe someone can expound on this a little more.
angel2794
Sep 8, 2015 06:22 PM
f-bodyz28
Sep 2, 2015 05:03 PM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
theurge
Aug 21, 2015 12:46 PM
