pic of a TBI engine rght?
Old Jan 30, 2002 | 06:56 PM
jeemydRS's Avatar
this is aTBI engine correcT?
Old Jan 30, 2002 | 07:12 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yeah that looks like a TBI engine. it would be easier to tell if there was no air cleaner on
Old Jan 30, 2002 | 07:35 PM
Buck268's Avatar
You can tell it is a TBI engine b/c the earlier carbs (at least on thirdgens...) had the alternator on the other side where the A/C conpressor is on L03's...Now, if that aint outta a thirdgen, I couldny tell ya if its carbed or TBI w/ the air cleaner on...
Old Jan 30, 2002 | 07:58 PM
jeemydRS's Avatar
its a pic from my 91 RS it has a 305 in it.. i just dont know how to tell wether its a TBI or TPI...
Old Jan 30, 2002 | 08:05 PM
Tas's Avatar
Tas
= TPI
Old Jan 30, 2002 | 08:07 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Someone already used this description previously, but it explains it simply ad concisely. TPI: Looks like a huge silver spider is humping your engine. TBI: Looks like a big trash can lid on top of your engine. You have a LO3 engine aka 305 ci. Peanut cammed TBI. Welcome to the club. Lon
Old Jan 30, 2002 | 08:11 PM
jeemydRS's Avatar
well now that i know what i have thats a good thing. cause as ya can tell im pretty new to the car thing.
Old Jan 31, 2002 | 04:19 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Hey dont worry
I was just like you..
all confused, didnt know the difference between a TBI and TPI also, but people gave info and now u learn, slowly slowly!
Old Jan 31, 2002 | 05:55 PM
vjo90RS8's Avatar
Car: 2002 Z28
same here, i didnt know anything about my car last year, started coming to this site and did a lot of reading. Within a few months was doing my own headers along with alot of other stuff, and found out that it is a whole lot of fun. but it sucks now being at school, no time to work on my baby. I guess ill just have to wait until spring break. Just do a lot of reading and you will learn
Old Feb 2, 2002 | 12:24 AM
HrdRockA4305's Avatar
I can't belive I'm been on this board almost a year now, and the amount of knowledge I've absorbed here is just amazing. You guys are in the right place!
I still love the "spider humping the engine" analogy
Old Feb 2, 2002 | 02:47 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
HrdRock: you're tellin me! When I started going on message boards a few years ago I didnt know the difference between a head and a headder. Now Im going to be porting my own heads and putting a cam in my car. Its so cool... imagine having to go to the *gasp* library and *gasp* getting a book to learn this stuff!
Old Feb 2, 2002 | 07:00 AM
DM91RS's Avatar
Car: 91 RS
Re: pic of a TBI engine rght?
Old Feb 2, 2002 | 11:37 AM
Buck268's Avatar
DM91RS, I will not say that the pic u posted is not TBI, but I will say that it aint the L03...The laternator is on the wrong side
Old Feb 2, 2002 | 06:27 PM
DM91RS's Avatar
Car: 91 RS
LOL You're right, it's now the HO3
Just some changes to make it more to suit me.
Old Feb 2, 2002 | 06:32 PM
DM91RS's Avatar
Car: 91 RS
Sorry it's so messy with the wiring and ty-wraps but I'll get some recent pic's in a few days after I finish the valve cover change.
Old Feb 2, 2002 | 06:40 PM
Buck268's Avatar
If you dont mind.. Why did you switch the alternator around? Also, whats up with the air cleaner? It has the L69 style ducting, but only 1 of em.
Old Feb 2, 2002 | 06:58 PM
Tas's Avatar
Tas
It looks like a preserpentine setup but with serpentine belts?? I'd like to do the same. That looks clean. Do you still have the smog pump and power steering pump? I wana get rid of my air condition soon.
Old Feb 2, 2002 | 07:38 PM
DM91RS's Avatar
Car: 91 RS
I needed to use the alternator as a takeup for the belt and after removing all the crap on the pass. side a pulley was needed in that location for proper belt wrap. Also on the driver side mount it was a pain to remove the valve cover it was so close.
As far as the air cleaner you are correct in that I only have one of two ducts hooked up. I have some things out of the engine bay in those photos while working on things. I am also missing the strut tower brace. By the way I could tell no differance with two ducts hooked up to the air cleaner and if you stop to think about it look under the hood of a 2002 Vette and check the single hose that it has feeding a much higher output engine.
Old Feb 2, 2002 | 07:42 PM
Buck268's Avatar
Thats a good idea to relocate the alt. Maybe if I ever get 2 pulling A/C and AIR, i will do it.
DM91RS's Avatar
Car: 91 RS
It is the stock LO3 setup that has the driverside bracket modified and I made the alt mount and takeup (not painted yet).
No smog but the power steering is in the stock location
Old Feb 2, 2002 | 07:50 PM
DM91RS's Avatar
Car: 91 RS
Buck I forgot to mention that the air cleaner is the stock LO3 that has been modified to use the larger 4" ducts, has no ring down in the throttle body and uses a 1" taller lid from a LO5 cop car to get a larger filter in there.
It's all eazy to do
Later
Old Feb 2, 2002 | 11:10 PM
Buck268's Avatar
Ah. Yes, that makes sense, since it wouldnt make much sense to close up another snorkle!
That hose you are using is it the ducting for the L69, or is it something else? Right now I just got the base, no snorkles, and I really dont wanna pay $55 for some plastic. I dont wanna pay $55 if I can get away with something cheap that looks...not cheap...
Old Feb 3, 2002 | 06:21 AM
DM91RS's Avatar
Car: 91 RS
Buck.... the ducting is stock replacement from Autozone. For what auto I don't remember as it was purchased in 1995. It does hold up well and it was around $10 then. It is longer than the stock L69 hose.
The hard plastic snorkal that's attached to the radiator support is the stock piece shortened on both ends. You don't really have to cut the front but the rear has to be cut until it is the large enough to match the 4" hose. If you need pics let me know.
Good luck
Old Feb 3, 2002 | 07:54 AM
Buck268's Avatar
So you got it at autozone? I wonder what its replacing...Maybe I'll check it out this week...time permitting. Unless you got a few already on your comp, I'll be ok w/o pix. but thatnx for the info!
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
