1st winaldl run - lots o' knock
Old Feb 17, 2002 | 01:24 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
I finally got around to soldering together a cable last night and let the car idle and revved it a couple times. Very cool new tool!
Most everything looked pretty good (BLM always 128, good steady O2 voltage, no sensors seemed out of line). The "rich" flag kept popping on then off every once in a while, but I'm guessing that's just noise (from my cable?) and not real? On the other hand, I had occasional knocks showing up and, if I revved the engine, the knock counts would go through the roof!
How do I know whether or not this is a bad knock sensor / sensor picking up noise vs. a real problem I ought to look into?
Old Feb 17, 2002 | 01:28 PM
Car: 91 Formula
Engine: 305 TBI
The log, if you want it
Oh yeah - here is the log file, in case you want to see it...
btw, the 32 (EGR) code is set b/c my EGR is not working; it comes on while crusing warm / in closed loop. The code 44 is old, from when I was driving around measuring the O2 sensor voltage - I think the connector wasn't perfectly tight b/c it threw 44s twice, until I took my wire out of it.
If I'm missing something obvious, I apologize; it was late...
Old Feb 18, 2002 | 01:19 AM
JPrevost's Avatar
Car: 91 Red Sled
Probably running too much timing and the non-functioning EGR will cause timing issues and knock problems. Although it shouldn't at idle. It doesn't look aweful but you're running on the warm side ~205*F, everything else looks normal except for the knock. You might want to actually drive around and save the "spark count table" and post that up. Drive around for a while so you get lots of input and save the BLM table and post that also.
Old Feb 18, 2002 | 01:30 AM
Car: 91 Formula
Engine: 305 TBI
Yeah - dang EGR. It's hot b/c (1) I left the car idling for a bit while I oohed and ahhed at how cool it was to see all this data, real-time, and (2) I have a stock-replacement fan sw. Something just came to mind - this was my first low (87) octane tank of gas in a while. I figured that I'm not so far from stock that I couldn't run 87 anymore and wanted to see if there was a mileage diff. Do you think 87 is too low with my mods?
I wanted to drive around with it today, but couldn't. I'll post a spark count table as soon as I get time. Thanks for taking a look, Jon.
Old Feb 18, 2002 | 02:37 AM
Jza's Avatar
Jza
Re: 1st winaldl run - lots o' knock
's normal.
Old Feb 18, 2002 | 09:36 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
I never run anything but 92. 89 is okay but I get knock with 87 just like you said.
Old Feb 18, 2002 | 10:41 PM
Car: 91 Formula
Engine: 305 TBI
OK, here is the log file...
I drove around for 5 or so minutes, quick highway run. What is good/normal for BLM variation (ie never anything but 128 or fluctuation +/- 1 or 2 sometimes)? Without revving the engine, the knocks appeared steadily rising througout, independent of throttle/rpms...?
File Type: txt
Old Feb 19, 2002 | 04:17 PM
Car: 91 Formula
Engine: 305 TBI
Anyone?
24 people d/l'd the log, nobody has an opinion? Did I forget to log something important?
Old Feb 19, 2002 | 07:01 PM
Snowdog 91 Formula's Avatar
knock sensor?
New knock sensors for a 350? I have no clue.
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
