cat problems....
Old Feb 28, 2002 | 08:13 PM
NXS055's Avatar
cat problems....
im tired of my car being so quiet... i bought the muffler that is supposed to be loud and it still isn't.... i have the same muffler on my other car and its really loud, so i've decided it must be the cat... btw the car is a 91 camaro rs.... 305tbi so:
what are the upsides and downsides to removing the cat completely.... what about the sensor and stuff in there???
what about gutting the cat and puting a pipe through it??? would this be any better....
how much should i look for my local shop to charge for this??? thanks
Old Feb 28, 2002 | 08:22 PM
firbird's Avatar
local shop will not do it
Old Feb 28, 2002 | 08:29 PM
NXS055's Avatar
they'll take it off and weld a peice of pipe in there if i tell them to....
why not???
now the puting the pipe through the cat, i could understand, but why would they not just cut it out
Old Feb 28, 2002 | 09:08 PM
Faithbird88's Avatar
Its illegal, no shop in there right mind will do it, and if they do there not a shop who should be serviceing cars, you will find the sound you want and performance with a free flow cat, my buddy gutted his cat and it sounded and ran like S**t, sorry but that the truth of the situation, i know most people believe it works, the only thing that would be the best if any gutting is taken place would be to put a pipe through it , remember cat's serve to purposes one to convert biproducts of spent fuel to a not so toxic air as well as keep pressure on your valve,, now i know we really dont worry about pollution, but when you car becomes a gas guzzler and sounds like a gurgling garbage can, you'll wish you hadnt gutted your cat.
mike
P.S. This is totally my opinion, just giving some useful info
Old Mar 5, 2002 | 09:27 AM
NXS055's Avatar
Ok, so, what cat would you recommend... I'm on a tight budget right now, so best performance and sound for the least cash...
also, if i do this, will i notice a performance increase or is it not that much of a change
Old Mar 6, 2002 | 07:01 PM
PopaPork's Avatar
Broom stick it
My buddy up in NY put a broom stick threw his cat, said he didnt know a power gain really, but did notice sound. I can back that up his car was loud before and now it is a little louder. I think the hollowness of the cat lets the sound bounce around for a bit
Old Mar 6, 2002 | 07:12 PM
i just recently replaced my OEM cat with CatCo freeflow, it was $104 from summit handling and tax included, this was a direct fit you can buy universals for about $50 or so, now at first when i started it up i said "WOW" its not louder at all, but after about 15mins of running it and taking it around the block it sure sounds sweet, a nice deep performane growl you get from LS1's with Borla exhaust if you know what mean, my opinion freeflow is the way to go........
mike
Old Mar 7, 2002 | 02:47 PM
TopJimmy92rs's Avatar
the best converter to use is none at all, just put in a pipe were the cat used to be. sure its illegal just don't get caught. I have a dynomax ultra flow with no cat and in sounds really good its not quite thats for sure, but its not loud enough to get a ticket. so its a good system
Old Mar 7, 2002 | 03:25 PM
Tas's Avatar
Tas
if you just got a muffler and still have the stock single 2.25" pipe NO WONDER ITS QUIET! You can get a 3" hooker catback for $200.
Old Mar 7, 2002 | 07:36 PM
Keith5's Avatar
Car: C1500
My friend found a guy in honaker that will gut cats. You shouldn't have much trouble finding a shop around here that will do it. I'd suggest you do it yourself though. It's a hands on learning expirence and it's cheaper that way
Old Mar 7, 2002 | 10:21 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
shops will do it you just gotta find the right one. i had a local shop make a "test" pipe for $15. guy knew exactly what i was talking about and had it made in no time. but you are going to want to put 3" pipe on there if you want it to be louder
Old Mar 13, 2002 | 03:36 PM
NXS055's Avatar
well heres the deal. my car was and is running a little lean, so it was killing the cat. i went and had it gutted, and now i notice quite a difference in performance, and it sounds good enough for now... it was all black and gooey inside... yuck...
hahaha
so anyway, i'm happy for now
Old Mar 14, 2002 | 09:00 AM
TBI305Camaro's Avatar
when i get the money should i go with a 3'' exhaust? is it needed on a lo3? i THINK they replaced my pipe from the cat back with 2 1/2''...im not positive tho im about to put on headers and id hate to waste the flowmaster and the brand new pipe i paid 200$ for both so why get rid of it?? i was thinking about either getting a high flow cat without the air tube since i want have any emmissions crap except the cat right now...all you have to do here to get a shop to put a pipe in without a cat is to roll in without a cat and they will put a pipe in for you
Old Mar 16, 2002 | 08:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i hear lots of good feed back about random tech. cats. thats what im goiung to go with. Pricy as he!! though...
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
