Adjustable Fuel Pressure Regulator
Subscribe
Mar 19, 2002 | 11:04 AM
Hey, I got that AFPR from turbocity and that screw that comes out from the hole that u twist to increase or decrease, do u leave that in there when install it or how does that go in there?? Is it suppose to protrude thru the bottom of it when I install it and what is that cone thing for and where does that go? Thanks
Reply 0
Mar 19, 2002 | 01:13 PM
<-- shakes head while wondering why you didn't just make your own adjustable.
Anywho; Yes it's suposed to stick out. This lets you adjust the pressure without taking the injector pod off. That cone is where the spring sits. To increase the fuel pressure you need to screw down on the spring. The pressure regulator is on the return fuel line side after the injectors. If you back out the screw you decrease fuel pressure.
Reply 0
Mar 19, 2002 | 01:37 PM
I knew u would say that u son of a b*tch. :sillylol:
Reply 0
Mar 19, 2002 | 01:40 PM
Oh and thank u.
Reply 0
Mar 19, 2002 | 09:53 PM
how much was that. that is a helluva lot easier then taking the pod off everytime you want to make an adjustment
Reply 0
Mar 19, 2002 | 10:43 PM
I got mine slightly used for 45.00 but check to see how much they are at turbocity
Reply 0
Mar 20, 2002 | 12:59 AM
Is that the only reason you bought it? So u could adjust w/o removing the cylindar?
Reply 0
Mar 20, 2002 | 01:05 AM
righty tighty, lefty loosey
Reply 0
Mar 20, 2002 | 07:38 AM
No, because it was 45.00 shipped and it was from a friend, what does it matter? LoL.
Reply 0
Mar 20, 2002 | 04:14 PM
OK guys.....do you want me to show you how to make the stock pressure reg adjustable without removing it from the unit?
Reply 0
Mar 20, 2002 | 07:22 PM
Quote:
Yes
Reply 0
Mar 20, 2002 | 07:40 PM
No
Reply 0
Mar 21, 2002 | 04:13 PM
Quote:
Originally posted by 91Bird305
No
ll
Reply 0
Mar 21, 2002 | 04:20 PM
That's the help others spirit that we need on this board
U need some more? :sillylol:
Reply 0
Mar 21, 2002 | 05:02 PM
[Later
Reply 0
Mar 21, 2002 | 05:35 PM
quick questoin the fuel regulator says it can adjust from 9-13 psi so what is it stock set on 9psi?
Reply 0
Mar 21, 2002 | 05:53 PM
Quote:
Oh yeah....I forgot the new guy has to change the targets. LOL
I have no problem changing targets. I change from target to target everytime I off someone cause thats all they are to me is targets....
Reply 0
Subscribe
