WD40 into airdam?
Old Mar 19, 2002 | 06:51 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
WD40 into airdam?
Hey all
my car died today, my buddy said that at his garage they spray WD40 into the airintake, and try to start it and it apprently starts right up. Is this safe for your engine???
Old Mar 19, 2002 | 07:21 PM
dtpmike's Avatar
its combustable, so it probably didnt hurt anything. I wouldnt recommend using it regularly. They have starter fluid you can buy. Your probably fine.
Old Mar 19, 2002 | 07:48 PM
Tas's Avatar
Tas
??? I've sprayed carb cleaner to help start up when I've run out of gas to get them started again but WTF?
Old Mar 20, 2002 | 09:21 PM
Nasty_Bird_'90's Avatar
do yourself a favor and spend two bucks on a can of starter fluid. hopefully you wont need it on a regular basis, but its got ether in it which is highly combustible and when the time comes, thats the right stuff to use.
Old Mar 20, 2002 | 10:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yeah i just used starting fluid when my injectors werent priming the engine
85cmroz28
Oct 4, 2015 09:44 PM
Fox118
Sep 12, 2015 09:29 PM
Dante93GTZ
Jun 2, 2003 02:37 PM
Matthew91-Z28
Sep 1, 2002 11:06 AM
Jer82Z28
Jul 4, 2002 08:33 PM
