Airdams....
Old Jun 28, 2002 | 07:30 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Airdams....
What do the stock airdams look like??
I just made a homemade one with a truck mudflap cut in half.
just that little bit made a huge difference
before it ran at 225-230 on the highway
now it wont go above 195.
that was tested on a hot day.
Every camaro I looked at in the junkyard never had an airdam.
my home made one is the length of the rad crossmemeber. I screwed it into the xmember and the flap hangs down slightly and scoops in the air. is the stock airdam bigger than this?
Old Jun 28, 2002 | 11:21 PM
Desert86Roc's Avatar
Here is a pic of an orginal airdam after a year's use. I put an aluminum support behind it to "bend" if forward, but gave up the idea, and just buy a new airdam every year or so. A lot of people mistakenly remove this piece because it "scrapes" the ground when going up driveways and stuff.
Old Jun 29, 2002 | 08:59 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
Cool thanks! Mine is in the exact same place except it's at an angle pointing forward. I didn't think they woulda been pointing straight down like that, no wonder they get scrapped
Old Jun 29, 2002 | 12:17 PM
iroc22's Avatar
Re: Airdams....
That's probably because every airdamn on F-Bodies gets smashed up and people go get the junkyard ones because they're cheaper than the dealers.
I removed my airdamn 2 years ago and my IROC has never seen past 195*; even on the freeway on the humid summer days.
Old Jul 1, 2002 | 10:23 AM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Hey i am dealing with a fairly warm running 91 rs 5.0 and i noticed while i was replaceing the fan motor (because it died yesterday on a 98*F day. 3foot fountain of coolant when i opened the hood.), while retrieveing a socket from below, that i don't have an air dam. My car seems to run up to the 240 mark on the highway at which point the overheat sensor kicks the fan on. I was wondering were i could buy an air dam, for how much and what kind of differance i might see.
Old Jul 1, 2002 | 11:52 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
check Ebay, I remember seeing them for sale lots.
you can also try the salvage yards.
Old Jul 1, 2002 | 12:28 PM
robbob's Avatar
Do the airdams look the same on 85 TransAms?
Old Jul 1, 2002 | 03:17 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, it just so happens I just changed mine. Go to your local Chev Dealer and ask for part #14083929 and that will be around $25. Well worth the bread.
Auggie
Oh, I almost forgot. He said that this "Air Deflector" (air dam) fits 82 to 92 Camaros. I stand corrected. Good point, we should call parts by there proper name as much as possible.
Old Jul 3, 2002 | 01:24 AM
1986redbird's Avatar
NO, the air dams on the T-A's are quite a bit different that that of the camaros. the bird dams run across the entire width of the nose of the car and hang down about 3 or 4 inches, the kind of come to a point in the middle of the car and taper back as they move out to the sides of the nose.
Old Jul 4, 2002 | 08:33 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
One thing that confuses us is that we call this component an "air dam" of which there is no such part.
On the T/A's for example the cooling system consists of 3 main parts and none of them are called an air dam. So some people get confused on which part they are looking at or for.
<img src=http://www.gmtips.com/3rd-degree/dox/tips/cool/airdam.gif>
You need all three but the extra wide strip at the bottom is the "least" critical.
