smog crap question
Old Mar 29, 2002 | 11:18 PM
TBI305Camaro's Avatar
smog crap question
ok i have no air injection left besides the line going into the cat which still sits near trhe valve cover and the one that hooked the pass side air injection to the right side...my question is where is that hose hooked at? so far i wasnt able to get it out because its hooked somewhere...i want to get rid of that and when i get the headers the cat line will be gone to...
Old Mar 30, 2002 | 11:21 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
Re: smog crap question
im not sure what you mean, i ripped all my stuff out including the cat and just had a straight pipe welded in its place, i didnt know there was a passenger and drivers side air injection......maybe you mean the air tubes on the stock manifolds?
Old Mar 30, 2002 | 02:08 PM
racereddy20's Avatar
You need to jack up the car. Get underneath it on the passenger side. Look up you should see that its bolted onto the block. I ended up hacking the pipe off with a cutter tool and leaving the part still bolted to the block. I was starting to get rushed (sun was going down) and I needed the car up and running that day. I know what your talking about I had them weld that part of the pipe (next to the cat) shut.
lt1z350
Aug 28, 2015 05:57 AM
anesthes
Aug 26, 2015 01:37 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
