Need help with AFPR
Old Apr 7, 2002 | 06:43 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
Need help with AFPR
I did most of the ultimate TBI mods today. I was going to do the AFPR but Pablo's tech article was kinda cloudy to me. Can somebody else explain it a little better? Thanks!!
Old Apr 7, 2002 | 07:20 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
just drill out the cap on the top make sure that you use a right sized drill bit as big as you can. then make a little line in the screw. your done.
Old Apr 7, 2002 | 08:36 PM
fbody dude's Avatar
Car: 92 Camaro
Black_Widdow
I was a little confused with the instructions for that AFPR, too. But, once you take it apart and drill out the welded screw it all becomes clear. If you make a groove for a slot to use it like a regular screw you will have to take the afpr off every time you want to make an adjustment. PITA
Take a look at this thread. It is a better design. In fact, i saw holley had an afpr with this design.
https://www.thirdgen.org/techbb2/sho...threadid=93799
Old Apr 7, 2002 | 11:20 PM
So in this design it would be adjustable just by taking the air cleaner off and turning the bolt, right? That seems alot easier than Pablo's way. Maybe I'll try that tomorrow. Thanks!
Old Apr 7, 2002 | 11:58 PM
JPrevost's Avatar
Car: 91 Red Sled
Go to my website, there is a tech article on how to do it but with pictures. It's by Vader (moderator) and it's very descriptive. Just surf my site and you'll find it.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
