sonar_un
Old Apr 8, 2002 | 12:11 AM
racereddy20's Avatar
sonar_un
I know you just did your lt1 cam swap. How did you mill down the dowel pin on the cam, and how much metal was removed. I won an lt1 cam on ebay the other day. I am looking for heads and an intake before I do the swap. I want to prep the cam now though.
Old Apr 8, 2002 | 07:42 PM
anyone? Any input would be appreciated.
Old Apr 8, 2002 | 09:01 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I think he used a regular hack saw and cut it all off. I also bought an LT1 cam and need to do the same thing. I think there is a way to check his posts. Or try a search under something like "cam swap day 1" and so on, and you should be able to find it.
What really needs to be done is a tech article on this swap!!!
Old Apr 8, 2002 | 11:00 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Yeah, I used a hacksaw. I tried to get it as close to the same size as the stock L03 cam as possible. Worked perfectly. The peice of metal isn't very strong, so it really doesn't take much to cut it off.
Old Apr 9, 2002 | 02:33 AM
cool I was thinking that the metal on the camshaft was going to be like tool metal. I figure that I can cut it down or grind it down using an air cutter tool. I cut through some tack welds in a matter of minutes with the air cutter tool when I did my header install. Thanks:hail:
xtremeirocz
South Central Region
68
May 23, 2006 12:26 PM
Kandied91z
Apr 13, 2004 08:56 PM
Sonar_un
23
Jan 4, 2004 07:36 PM
Sonar_un
Feb 22, 2002 09:31 PM
Sonar_un
Mar 5, 2001 03:47 AM
