ATTN master mechanics, steering column question
Old Apr 15, 2002 | 02:34 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I am trying to repair my steering column thanks to an attempted theft of my car. What they did was smash out the site of the column, remove the ignition gear and manually slid the plunger to activate the ignition switch.
I have the gear back in place but there is another plunger above the gear that is held on by a spring. It pushes forward when turning the key. I cannot get the spring on in order for this second plunger to work. Does anyone know what it does? can I run without it?
Old Apr 15, 2002 | 09:20 PM
Nordbert's Avatar
That pin engages the lock plate when you turn the key to the
"OFF" position.You do not need it to operate the car, but your
car is more easily stolen if it can be steered. Do a search on MSN
for turn+signal+switch. #37 illustrated tilt steering column disassembly.
Old Apr 15, 2002 | 11:05 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
thanks!
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
