Heating up on the hiway...
Old Apr 15, 2002 | 03:43 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
My engine seems to get warm on the hiway. I'm talkin it heats up to 190*F...at idle it will be ~180*F.
Not terrible...but summer is coming and who knows if it'll stop climbing.
I have a new: water pump (hi-flow), radiator (3 core copper), thermostat (180*), hoses, fan clutch, shroud, goose neck. I JUST replaced the thermostat and goose neck. Turns out that the 4.3 V6 goose neck has an opening about the size of a quarter...barf. So I replaced it with a Mr.Gasket goose neck that has a MUCH larger opening.
The engine runs ~2000 rpm usual hiway cruise. At rush hour its about ~2200-2300 rpm.
Is this normal? I'm probably over-reacting but my IROC runs at 220* so I really don't have anything else to compare it to.
Old Apr 15, 2002 | 04:52 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Do they come from the factory with air dams??
Check your lower radiator hose, to make sure it's not collapsing.
Old Apr 15, 2002 | 05:17 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
The lower hose is a flex hose...it's real rigid and has a "spring" inside of it.
I may be too long tho...finding a radiator hose for a '92 Astro with a 350 in it is kinda difficult so I've been guessing
I think I'll try a hose 2-3" shorter...
Old Apr 15, 2002 | 06:20 PM
Stroked-Z's Avatar
Are you leaning out at higher RPM?
Old Apr 15, 2002 | 10:50 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
According to my scanner I'm always rich on the hiway.
Old Apr 16, 2002 | 07:51 AM
82camaro's Avatar
Car: 82 camaro SC
190 down the highway is no problem at all. Your fan clutch will probably kick in at about 220 and cool it down if needed. With a 180 thermostat, it is probably just getting fully open around 185 or so. If it ain't broke, don't fix it.
Old Apr 16, 2002 | 09:57 AM
camaro6spd's Avatar
yep
i get about 190 on the highway with my 180...if you want cooler try a 170....that should give you the 180* you are lookn for.
Old Apr 16, 2002 | 10:23 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Thanks for the replies
Old Apr 16, 2002 | 11:20 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
electric fan???
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
