i dont get this!! cvr starter wont fit up with my new 400
Old Apr 16, 2002 | 09:26 PM
2ponchos's Avatar
i have cvr part number 5323 and i cant seem to get that darn thing to fit up right.. my 400 has both sets of holes for the starter.. i tried everyway i can think to turn the starter but the starter bendix i think its call hits the fly wheel.. this is the same starter i used on my 350 tpi and i know the fly wheels are different but it just seems my 400 fly wheel is just way to big or something..
i also called jegs and talked to them and they said that this is the right part number for my motor soooo what could be the problem
this is now all that is holding me back from starting this darn car!!! help asap thanks!!!!
Old Apr 16, 2002 | 09:55 PM
2ponchos's Avatar
also is there a web site for cvr starters?? and maybe if someone has the phone number that would be great i need to get this figured out asap thanks
Old Apr 17, 2002 | 12:25 AM
Blackened's Avatar
You might have a 14 inch 168 tooth flexplate on that motor. What flywheel did you use ?!? The "TPI" flexplates are 12 3/4" and 153 teeth. A starter for your year car and engine wont work with a 400. You would need a starter designed for a 70 something 400.
Old Apr 17, 2002 | 12:31 AM
2ponchos's Avatar
yeah but when i called jegs they say this is the right starter.. i have been searching the board.. i c others have been using the same starter hopefully one of them sees the post and replys.. jegs also said since i asked bout if the year of the blcoked mattered and they said no since the starter in basically universal
Old Apr 17, 2002 | 02:50 AM
Blackened's Avatar
That's not what I'm saying though. If the flexplate is 14 inches then of course it wont fit. Find out what kind of flexplate you have and make your life easier... I'm only trying to help you out
Old Apr 17, 2002 | 02:54 AM
2ponchos's Avatar
blackened i am not trying to argue with ya just saying in the jegs catalog it states that the starter i have is good for all chev v8's 153 teeth to 168 teeth.. so basically that makes it universal at least that is the way i take it.. i am going to screw with it some more i did search the boards tonight and see that people with 400's are using the same starter i jsut hope they reply and can help out!!!!
Old Apr 17, 2002 | 04:24 AM
Blackened's Avatar
True. Well if it says that.. there's gotta be some sort of adjustment for 153 or 168 teeth. I'm sure you can't just simply bolt it on and expect it to fit for both type of flexplates. Find out what you have to do to make it work.
Old Apr 17, 2002 | 04:27 AM
2ponchos's Avatar
i wish svr had a web site.. so i could get a hold of them.. but i will try to figure this thing out again in the morning.. damn motor swaps anyways lol
Old Apr 17, 2002 | 10:08 AM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
2ponchos here's the web site CVR Products
Old Apr 17, 2002 | 11:24 AM
2ponchos's Avatar
thank you very much!!!!!
Old Apr 17, 2002 | 01:39 PM
2ponchos's Avatar
hey hey guys figured it out!!! had to grind the **** out of the mounting block on the side where the header collector was hitting it.. at least i think i got it.. i am waiting for the guy that is helping me for him to check to make sure it will mesh but i think i got it!!!!
Street Lethal
Apr 30, 2019 12:14 PM
mhatfield 14
Oct 24, 2015 07:48 AM
5spdcamaro
Aug 28, 2015 02:12 AM
milk
Aug 10, 2015 06:26 PM
