Pushrod clearance ?
Old Apr 16, 2002 | 09:30 PM
steve8586iroc's Avatar
Pushrod clearance ?
I'm building a 350 with Vortec heads as it seems half of the people posting here have or are planning to do. My question is this. As I was checking the pushrod clearances I found that I had only about .025" clearance between the pushrod hole and the pushrod. I'm using the GM Hot Cam Kit with the 1.6/1 RR's. As I was reading the instructions that came with the kit it said that a minimum of .040" is required. What is the best way to clearance the pushrod holes and from your experiance is it nessasary to have a minimum of .040" clearance? Had I known at the time I had the heads being machined for spring retainer to seal clearance i would have had this done as well. Thanks for any help or advice you can give.
Steve
Old Apr 17, 2002 | 04:21 AM
ede's Avatar
ede
if it says .040 at least then i'd shoot for that, try a die grinder to open the holes up
Old Apr 17, 2002 | 05:43 PM
Thanks ede. Will do.
Steve
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
91 SrS
Oct 7, 2015 04:32 PM
mfp189
Sep 27, 2015 09:25 AM
