Alternator And Belt
Old Apr 17, 2002 | 03:49 PM
1984Camaro's Avatar
Alternator And Belt
How do i loosen to belt on an 88 camaro sport coupe. it is just 1 single belt throughout the thing. Im not sure how to loosen and tighten back up the belt. You can'd do it through the alternator cause that just bolts on normally unlike most other cars that have the sliding bolt hole so you can tight and loosen the alternator to adjust the belt.
Old Apr 17, 2002 | 04:04 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Oops, just read you done have the sliding bracket.
My alternator is on a bracket that the bolt you loosen will slide back and forth, sliding it out will tighten the belt, I just use a long screwdriver to get some force against the alt to get it totally tight.
Old Apr 17, 2002 | 04:09 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
On my car there is a wheel on the oposite side of the alternator that you put a ratchet in and just pull it back. With it pulled back you can undo the belt. The whole thing is spring loaded so it keeps the belt on there nice and tight. I like it, I can remove the belt without loosening any bolts.
Old Apr 18, 2002 | 12:57 AM
rezinn's Avatar
That's right. You need a 1/2" drive ratchet to pull the tensioner back. The belt will come off easily this way.
Old Apr 18, 2002 | 04:11 PM
1984Camaro's Avatar
Thanks it worked... See i was pulling the wrong way. Cause i wasnt sure if it was spring loaded or not then i tried the other way and it workerd.... Thanks
RS Reaper
Oct 17, 2018 07:52 PM
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
