Question about "Installed Height" of valvesprings.........
Old Apr 18, 2002 | 04:33 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
So if my vortec heads have a stock installed height of 1.750.......does that mean i MUST get an aftermarket spring with a 1.750 installed height as well?? Or can I get the more common 1.700 and use offset retainers or shims? Thanx Also.........can I use ANY brand valvespring that works to .510 lift if I have a Comp Extreme cam even though they say to use their specific brand?
Chris
Old Apr 18, 2002 | 06:14 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
you don't have to use a specific vs
1.75 is a little low.. smallblocks are normally 1.8 or a little more
Old Apr 18, 2002 | 09:09 AM
Vader's Avatar
Chris,
The key factors are pressure at lift/seat pressure (spring rate), and coil bind height. The installed height is not a big issue if the seat pressure is adequate and the spring can tolerate the lift as installed.
The often quoted installed height of 1.710" is a guide for a completely stock setup. Isn't it odd that other engines have installed heights of 2.40" or more and run just fine? Study the geometry and you'll be able to determine what is appropriate for your engine.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
