fans always on
Old Apr 18, 2002 | 08:32 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
fans always on
I took my ta out today for the first time this season. Thank *** my winter ride was getting a little boring. Nothing compares to a v8.
My problem is my fans are running all the time even when the car first starts from cold. Does anyone know what the problem is. It was hot out about 80+ temp. The car ran great but the fans shouldn't come on till about 190-220 i think.
Old Apr 18, 2002 | 08:42 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Have they always been like that since you got the car? Cause I don't see how all of a sudden they would just run all the time.
Old Apr 18, 2002 | 10:05 PM
91blkta's Avatar
cars been sitting for the winter. I dont recall it being a problem last summer. But I only put about 2000 miles on the car last summer
Old Apr 18, 2002 | 10:55 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
It may be that the relay is stuck in the closed position. That's what happened to mine.
Old Apr 18, 2002 | 11:15 PM
91blkta's Avatar
where is the relay located that runs the fans
Old Apr 19, 2002 | 10:39 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Mine was in the front of the car near one side of the fan. Just find the power wire at the fan and follow it back. I have heard of the relays being in different places. I don't know why. Mine was near the fans though.
Old Apr 19, 2002 | 11:05 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Correct me if I'm wrong but there is this little censor that screws in your intake manifold that might be the cause. My Dads 3rd gen camaro had a problem like that. I had a spare manifold that had the same peice, his was broke so we swaped them. The bad part is he broke it when installing it. :nono:
Old Apr 19, 2002 | 11:27 AM
rezinn's Avatar
Intake sensors have nothing to do with the fans. The fan relay is probably on the passenger side beside your radiator. Behind yor battery if it is there. You may want to check that the wire to the sensor in your passenger side head isn't grounded on your header also.
Old Apr 19, 2002 | 12:20 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
more than likley if it wasn't doing prior then it would be the relay.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
