rebuilding 305
rebuilding 305
Im buying a rebuild kit from summit for my 305. Now what i wanna know is after i cut the wear rings on the top of the clyender wall what do i have to do next. Basically what im asking is what should I do after that
thanks
thanks Joined: Mar 2000
Transmission: 4L80E/4L80E
Take the block to a salvage yard. Let them have it.
Pick up a rebuildable 350 shortblock.
Yes, I'm serious about that.
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
a used 350 is cheaper than rebuilding a 305 and it's a better engine -4" or bigger bore forever!!!!
Car: 1986 Trans Am
It's up to you
You need to decide what you want from the car as to determine what kind motor you want....you want a car thats easy on gas and dependable,use the 305...If you want a bad*ss,go with a 350,383,400....
yeah i know i want it to be a daily driver and do a work to it like a cam and stuff but nothing too crazy cause its gotta be emission friendly. I dunno i guess ill ask my teacher about the cylender walls
someone972
Aug 30, 2015 12:52 AM
