Limited Slip/Open/Posi
Old Apr 20, 2002 | 10:58 AM
gruveb's Avatar
Car: 1989 IROC-1
How do you identify what you have withOUT opening it up?
I don't have posi...I've jacked it up and checked....
However I don't think I have a "one wheel wonder" either....but how do I verify what exactly I have?
I'm not new, just a slow learner!
:lala: :lala:
Old Apr 20, 2002 | 12:50 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
posi/positraction is a limited slip differential. if you don't have a limited slip you have an open diff. the only other way is a locker which i'm sure you don't have.
Old Apr 20, 2002 | 02:29 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Give us the rpo code for the rear. If its G80 then its limited slip.
Old Apr 20, 2002 | 05:09 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
if the rear axel has never been open up there should be a meatel tag with limeted slip diff fluid on it if it's a posi (linited slip- same thing) also you can jack up one side put the tranny in nutral and try to turn the back tire if it turns - it's a open if it's hard (50 ft' lbs allot more torqu than I can put on a tire) it's posi, this is the proper GM approved way of checking if your posi works or is worn out also, if you are he-man I would put blocks in front of the front wheels, if the posi works it should take approx 50 ft lbs to berak it loose and 40 ft lbs to keep it going, which is more than you can turn the wheel by hand (unless you have allot of spair time on your hands )
Old Apr 20, 2002 | 06:11 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
If it can turn and the other wheel spins the opposite way your screwed just like me. ****ty one wheel peel....
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
