overflow tank cap
Old Apr 20, 2002 | 11:09 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
overflow tank cap
if the overflow tank cap on a 89 IROC does not screw down snuggly,goes on ,but does not appear to tighten when turning,can this cause an overheating situation??trying to clean out area to work on car to solve the new overheating problem that has occured recently,the fans are not running when the gauge reads past 220,so going to change thermostat,flush system(even thou recent fluid replenish)and check on sensors,the one that controls the primary fan(ECM control)on passenger side between plugs?thanx for any advice ,help
Old Apr 20, 2002 | 11:39 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
sorry but no. The cap will have nothing to do with your overheating problem.
gta892000
Aug 11, 2019 11:16 AM
Bohemian
Aug 15, 2017 05:11 PM
Stryker412
Sep 20, 2015 06:59 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
