Third and fourth gear missing
Old Apr 22, 2002 | 10:31 AM
JDuncan's Avatar
I have 85 Camaro 2.8 liter and it has the 700-R4 transmission, and after fixing my previous problem I was test driving it and 3rd and 4th gear just went out. You can manually put it in 1 or 2 and they work but when you shift to 3rd or it automatically shifts to 3rd it is just like hitting neutral. The shift linkage had a bolt missing and the other was loose so I fixed that and checked the fluid but still the same problem. Is it possible that the TV cable has something to do with this? I have never disconnected it or anything but I was crawling all around the engine compartment trying to get the distributor out earlier.
Old Apr 22, 2002 | 11:03 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Sounds like you need a tranny rebuild. The 3-4 clutches are toast.
Old Apr 22, 2002 | 11:15 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Same thing happened to my 89 marquis. The grommet for the TV rotted off the throttle body and I burned up 3rd and 4th, just like you said went into 2nd fine but then felt like neutral. If you catch it soon enough you may be alright, but if its already neutral it probably toast. It cost me $1200 to get mine rebuilt. Good luck.
Chris
hectre13
Dec 11, 2023 08:14 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
beastin91rs
Oct 9, 2015 07:38 AM
InfinityShade
Aug 22, 2015 08:00 PM
crazynights
Aug 21, 2015 06:53 AM
