High Torgue Starters????
Old Apr 23, 2002 | 11:28 PM
SlowStangEater's Avatar
Which is best for a 305 and which will fit???
Old Apr 28, 2002 | 01:12 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Is a high torque starter really needed for a 305? What kind of problems are you having with the stock one? Ive started some high compression engines with just a stock high torque starter.Or,if you just want one,go for it!
Old Apr 28, 2002 | 09:21 PM
I need one that handles the heat better. But I think Im just going to go with a Remote Solenoid instead.
Old Apr 28, 2002 | 10:23 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
I have heard alot of people do that(remote starter) but I never thought it was that bad.I had a 454 Suburban I used to tow with,it ate up starters.I bought a heat shield from JEGS,problem solved! So either way would be ok.
Old Apr 28, 2002 | 10:27 PM
NOT TRUE!!!!!!!!!!!! I have a thermal wrap and a Metal heat shield on it and i still have problems...............However it may be due to the fact that this starter had the problem before the shields were put on..................So it may be at a lower level if you know what I mean.
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
corey8084
Sep 17, 2015 02:56 PM
Cleotiz
Sep 16, 2015 08:02 AM
Formula_88AE
Sep 3, 2015 01:47 PM
