Head Gaskets: 305 + Vette Heads
Old Apr 24, 2002 | 08:21 AM
LimaBravoNiner's Avatar
Car: 89 GTA, 89 Formula
Engine: L98, LB9
Transmission: Auto, 5-Speed
Hey All,
I'm gearing up for swapping a pair of Vette AL heads on my 305 and I'd like to get opinions on head gaskets. My plan is to use GM P/N 12557236 which should be the gaskets used on the ZZ4 crate motors with these heads. I realize that my car originally came with steel shims and that I might lose a couple of tenths of a point on my CR. Reasoning for not going with the steel shims is for piece of mind against leaks on a 93k mile motor (my stockers appear that they may have been leaking slightly).
Any thoughts either way on the subject?
Old Apr 24, 2002 | 03:42 PM
iroc22's Avatar
Forget about the steel shims. It sounds like a good idea to go with because of possible leaks.
I hope you have the TPI base plate bolt pattern all sorted out.
Old Apr 25, 2002 | 06:41 AM
Engine: L98, LB9
iroc22,
I found another composition GM gasket (10105117) which is about .028" compressed and is closer in thickness to the original shims. I'll probably go with that one instead. Yep, I've got an '85 TPI base all ready to go...
Thanks for the heads up.
Old Apr 25, 2002 | 03:54 PM
E-Z Rollin's Avatar
The head gaskets I used for vette heads on a 305 were Ferrera's [spelling]. They had the best combo of thickness and bore size that I could find .035 and 4.060.
Old Apr 25, 2002 | 04:47 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm using GM p#10185054 with my set-up.
Rob
xkingcodex
Feb 12, 2020 07:43 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
