fouled plug on #6
Old Apr 24, 2002 | 06:56 PM
cherrybomb86's Avatar
fouled plug on #6
just did intake gasket on my tpi motor because rear was leaking from cheesy rubber. now #6 plug keeps fouling. this was due to a burnt wire. replaced wire and ran to try and clean but car still skips. im going to assume that for some reason the intake didn seal properly as plug is white hott and oily. no real noticeable oil consumption is present. car ran fine beforehand so it must be the problem or i didnt torque accordingly for whatever the reason car runs crappy now am i on the right track or what? any ideas would be appreciated. going to tear down runners this weekend and check bolts for tightness and possibly replace gaskets again. also going to run compression test beforehand (even though i did past summer when installing new cam and 120 was consistent across all 8)
Old Apr 25, 2002 | 10:22 AM
Vader's Avatar
Before you get carried away with disassembly again, install a new plug in that cylinder. Many time a fuel-soaked plug will be grounded through the insulator and never fire. Once this happens, there will never be enough heat generated to "dry" the insulator.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
