How many of you had tried to fix a problem
Old Apr 25, 2002 | 08:23 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
and created new problems????
changed sensors
now temperature gauge don't work???HELP!!
Old Apr 25, 2002 | 09:02 PM
rezinn's Avatar
What was the first problem?
Does the guage read too high or doesn't even move? Have you checked the wiring?
Old Apr 25, 2002 | 09:22 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
started with cracked end cap
started one morning when i noticed on the gauge overheating,had an end cap that cracked,so repaired radiator,and waould still overheat when not moving,due to fan/fans not coming on unless AC was on max,changed 2 sensors,and changed plugs,now today for test drive,noticed no movement from gauge at all?????don't know if ran long enuf to get hot enough for fans,no temp. gauge??if gauge not work,does ecm know???seems like alot of work for nothing,just another problem??
Old Apr 26, 2002 | 10:29 AM
Vader's Avatar
Did you refill the system and purge ALL air? Getting the air out can be tedious.
Old Apr 26, 2002 | 11:04 AM
TBI305Camaro's Avatar
happens all the time...while trying to remove my air injection i broke the map sensor into 8 million pieces...i think i messed up the EGR somewhere puting on headers to
Old Apr 26, 2002 | 01:27 PM
gruveb's Avatar
Car: 1989 IROC-1
breaking something else while fixing one thing is a #1 reason why I enjoy taking my car to the mechanic. He breaks it, he fixes it!!! It's a lovely arrangment!
But yes, it absolutely sucks. I swear! They design this stuff like that on purpose.
One day I was changing my oil on a 92 Grand Prix...the filter is right next to the Oil Pressure sending unit...which is very, very plastic and fragile.
I just bumped it and the F*cker broker off! So a little oil change cost me an additional $30.00.
Old Apr 26, 2002 | 04:59 PM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
heh, I know just what you mean. It may just be my dumb ***, but I break stuff half the time I'm fixing other stuff. Its kindof ghetto, but when I broke my temp guage sending unit, I reattatched it with a paperclip. On mine its on the front of the driver side head.
Old Apr 26, 2002 | 05:30 PM
gruveb's Avatar
Car: 1989 IROC-1
I had hooked mine up with an alligator clip and a jumper wire for a couple of weeks until I finally decided to buy another connector.
Old Apr 26, 2002 | 05:46 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
will air pockets
cause the gauge not to work,or did i not get it hot enuf??i ran it a few miles @15minutes,,but because of no gauge it came to the house,if it did get hot,the fans still didn't kick on??
Old Apr 26, 2002 | 05:50 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
found the one on driver side
i didn't appear to break it,the wire is still connected,but did touch it when pulling the plug wire,fixing to drive it anyway,hope she don't blow!!
theshackle
Mar 5, 2017 06:37 PM
dyeager535
Aug 28, 2015 08:10 AM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
