Z28 Tire Size..
Old Apr 25, 2002 | 10:52 PM
86RedZ28's Avatar
Z28 Tire Size..
I have an '86 Z28 with stock 15 inch wheels. I need new tires and I'm not going to upgrade the rims yet. Anybody know what's that biggest tire I can go with?
I currently have 215/65/R15
Tire shops say I can go to 225 or 235 but they said they're not sure. Just wondering what works for you guys.
Thanks.
Old Apr 25, 2002 | 11:01 PM
Jester's Avatar
235/60/15 all the way around works great and won;t even throw off your speedo.
Old Apr 25, 2002 | 11:02 PM
primer84z's Avatar
i have 16" rims and 255 on the back and 225 on the front. dont know how much of a difference a 15 inch rim would make.
Old Apr 25, 2002 | 11:04 PM
86RedZ28's Avatar
Thanks guys...I was thinking about going with the 235's....one shop here said it was too big, but I think it will work.
Old Apr 26, 2002 | 01:05 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
235/60R15 was actually optional on the 86. i believe it was standard on the L69 models.
Old Jan 26, 2011 | 04:19 PM
donward71's Avatar
Re: Z28 Tire Size..
will 295/50/15 fit under an 86 z28 on the rear with 15x8 with 4.5 backspace?
Old Jan 26, 2011 | 04:24 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Z28 Tire Size..
235/60r15 was an optional tire size, I wouldn't go back to that shop. Go on tire rack and it should list 215/65r15 as factory, 235/60r15 as optional. If you were doing a rim upgrade you could do 245/50r16 with no problems as well.
Old Jan 27, 2011 | 05:05 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Z28 Tire Size..
I am running 255/60/15 in the rear. Pretty good clearance and doesn't rub.
Old Jan 27, 2011 | 05:08 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Z28 Tire Size..
those 245/50/16 are a low profile tire and harder to find. I have 16 inch rims in the front and switched from the stock 245/50/16 size to a 225/60/16. They look beefier too.
Old Jan 27, 2011 | 05:09 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Z28 Tire Size..
http://www.tacomaworld.com/forum/tirecalc.php Check out that link. Lets you enter tire sizes and compare different views.
Old Jan 27, 2011 | 05:10 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Z28 Tire Size..
245/50/16 was Iroc standards.
Old Jan 27, 2011 | 05:16 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Z28 Tire Size..
http://www.camarotech.com/WheelsAndTires.html
this has a chart for the largest tire you can run
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
greenyone
Sep 2, 2015 03:39 PM
Ducati900ss
Sep 2, 2015 09:05 AM
